Author Topic: 73 Challenger Dash HELP (NEWBIE)  (Read 3919 times)
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
« on: May 21, 2008 - 01:47:18 PM »
:working:
I am new and need some help with my 73 Challenger. I have a Stock (NON-RALLY)dash in the car now. I am switching it out for a similer stock dash in better condition and a clock. My problem is that I was not able to figure out how to remove the original dash properly. The cover hangs up on the speedo and the steering column. What is the trick to removing the panel?  :sly:
ANY HELP WOULD BE GREAT!! THANKS !!
NATE
Re: 73 Challenger Dash HELP (NEWBIE)
« Reply #1 on: May 21, 2008 - 02:00:03 PM »
IF anyone cares here is a picture of the old lady
Offline Bart
« Reply #2 on: May 21, 2008 - 02:32:38 PM »
Hey Guy's let help the new guy out, I told him to come over here that this site has great people and would help. I know you all will.
Bart
Tripple-Green I'm sure that someone that knows will answer.
« Last Edit: May 21, 2008 - 02:35:32 PM by Bart »
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Offline matt63
« Reply #3 on: May 21, 2008 - 02:47:36 PM »
The speedo cable has to be disconnected.  There is a little lever/clip that has to be pressed down (if I remember accurately) before you can pull the cable out.  I think the column has to be unbolted from the bottom of the dash and at the firewall to drop it down enough to get the cluster out (at least it does in my Cuda).
Matt in Edmonton
'68 Valiant
Offline NoMope Greg
« Reply #4 on: May 21, 2008 - 02:58:34 PM »
Anyone does care - that looks like a gorgeous car!  Welcome to C-C.com.  You'll find lots of help here - I'm sure the membership here will be able to help solve your problem.  What part of CA are you in - maybe a local member can help you out.
I'd suggest starting a new thread in the Interior section with some photos of what you're trying to do.  You say it's hanging up on the speedo, but I'm assuming you mean the guage cluster.  Are you taking out only the pad?  If so, it's lot easier to do if you at least loosen the steering column at the firewall (four bolts) and lower it down some.  That should make the pad easier to get out.  Same thing with the guage cluster.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #5 on: May 21, 2008 - 03:21:48 PM »
Thanks, I was worried that I may need to drop that column to do it.
I am in Orange Ca.
I will be needing a ton of help on this one. This is my first dodge and wow am I lost at times.
Thank you for your help. I am sure this place will come in more then helpful.  :ylsuper:
« Reply #6 on: May 21, 2008 - 03:42:09 PM »
 :wave:  welcome triple green.  You will see that removing the dash is fairly simple. Drop the column down as said , it is easy, also take the panel switch out first along with the dash light bar. I think it's a 3/8th wrench that unhooks the amp gauge, speedo is a no brainer as mentioned, the bulbs for the gauges are color coded wires and marked on the back of your cluster.  Take a mental note as to a certain screw on the switch panel , as it will have a metal tab on that panel for a ground.
« Reply #7 on: May 21, 2008 - 05:54:14 PM »
Thank you so much for all your help. I was really stuck. I have a few other problems but I will try to post them in the correct section. THANKS!!  :newbie:
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #8 on: May 22, 2008 - 01:58:36 AM »
Welcome to the site   :2thumbs:
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #9 on: May 22, 2008 - 02:23:21 AM »
 :wave: Hello and welcome to the site TRIPPLE-GREEN.  Your '73 looks like it just rolled out of the showroom....unmolested.  Like to see more pictures when you get the chance to post 'em.  Good luck with the dash.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline hezzel
  • Matching numbers 383 Magnum ,727 at and 3:23 rear
« Reply #10 on: May 22, 2008 - 02:54:59 AM »
1971 Dodge Challenger R/T
2019 Toyota Rav4 Hybrid
« Reply #11 on: May 22, 2008 - 11:45:16 AM »
I am the second owner. The car was my grandmothers. She kept the car in almost show quality. I will be honest she loved that car more then anyone or anything else. Other then some wiring problems and a need for a new vynel top the car is in wonderful condition. It has been my daily driver for a little over a year now and never given me a wimper of a problem. GREAT CAR!!
I have a NOS Green top I am having installed in the next month or so and I am just trying to wake it up a little within the stock options. (Stock 4brl intake, duel exhaust conversion, exc.) but I want it to look like it rolled off a 1972-3 magazine ad. I have gotten a great deal of joy over people  :drool: over the fact that it was so untouched. The car is just to clean to Hot Rod and has been to good a driver to trailer.
Offline Slotts
« Reply #12 on: May 22, 2008 - 02:19:03 PM »
Hey Tripple-green, :wave:
Welcome to the site! Pretty car!
Make sure to disconnect the battery so there are no unexpected surpises pulling out the dash. ;)
Slotts
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #13 on: May 22, 2008 - 03:31:46 PM »
Welcome, TRIPPLE-GREEN!  :wave:
Sorry, not much help on the dash but I love the lok of your car!  It looks sooo original!  Any details on it?  Maybe do a Newbie intro?  :clueless:
Offline NoMope Greg
« Reply #14 on: May 22, 2008 - 07:12:09 PM »
Uhh...Phil?  From two postings above you:   :poopoke:
Greg
