Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
3rd member swap
« previous
next »
Print
Pages: [
1
2
Author
Topic: 3rd member swap (Read 2881 times)
Belgium Cuda
Full Member
Living in Belgium but beeing Swedish
3rd member swap
on:
May 21, 2008 - 03:59:48 PM »
My Cuda has today a -741 non diff and 4,88. Very irritating to drive with. Now I bought a -742 suregrip 3,23 and would like to know
if the driveaxles will fit now?
Logged
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Moparal
Permanent Resident
Re: 3rd member swap
Reply #1 on:
May 21, 2008 - 04:07:07 PM »
They should swap just fine. Be sure the center pin is in the 742 so you can adjust your axles if useing the stock bearings.
Logged
Belgium Cuda
Full Member
Re: 3rd member swap
Reply #2 on:
May 21, 2008 - 04:13:48 PM »
Center pin?
Logged
Moparal
Permanent Resident
Re: 3rd member swap
Reply #3 on:
May 21, 2008 - 04:27:03 PM »
If you look inside your 742, down where the axles go, you shouldnt be able to see through. There will be something blocking the way. This is good
Unless you have the non adjusting bearings on your axles that were called the green bearings, then it would come out. Your axles should have 30 splines and the same as the 742 sure grip
Logged
Belgium Cuda
Full Member
Re: 3rd member swap
Reply #4 on:
May 21, 2008 - 04:42:50 PM »
Will take a picture of it tomorrow and post so I am sure I know what you mean. Never worked with rear ends before.
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Re: 3rd member swap
Reply #5 on:
May 21, 2008 - 05:13:43 PM »
I hope it works out for you. I couldn't imagine driving with 4:88's.
You must redline at 40MPH.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
Chryco Psycho
Administrator
C-C.com Guru
Re: 3rd member swap
Reply #6 on:
May 22, 2008 - 03:46:50 AM »
all 8 3/4 diffs used the same spline ofr the axles so you are good there
Logged
Belgium Cuda
Full Member
Re: 3rd member swap
Reply #7 on:
May 22, 2008 - 04:00:52 PM »
Is it here I should see the center pin? Does it look in a OK shape?
Logged
FJ5_440
Full Member
Wisconsin
Re: 3rd member swap
Reply #8 on:
May 22, 2008 - 04:04:38 PM »
You need to look through the hole where the axle goes.
Logged
** Shane **
Belgium Cuda
Full Member
Re: 3rd member swap
Reply #9 on:
May 22, 2008 - 04:08:49 PM »
Aha, in the housing?
Logged
Belgium Cuda
Full Member
Re: 3rd member swap
Reply #10 on:
May 23, 2008 - 01:22:40 AM »
What kind of oil do I need and how much?
Logged
hooD
detroit iron
Resident
Motor City Made Muscle
Re: 3rd member swap
Reply #11 on:
May 23, 2008 - 02:20:55 AM »
Quote from: Belgium Cuda on May 21, 2008 - 04:42:50 PM
Sorry.....I had to laugh at that one!!!!
Logged
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
http://www.youtube.com/watch?v=1e4-yOrEEI4&feature=g-upl
*click my E-Body*
Chryco Psycho
Administrator
C-C.com Guru
Re: 3rd member swap
Reply #12 on:
May 23, 2008 - 03:20:51 AM »
that will not have the center pin , it has or had buttons as it is a clutch type sure grip
I would say it is not in OK shape it has surface rust on virtually all of the teeth & may be throuigh the case hardening , you may need a set of gears
Logged
Belgium Cuda
Full Member
Re: 3rd member swap
Reply #13 on:
May 24, 2008 - 07:40:26 AM »
Well it didn't start that good, after removing the brakedrum and loosen the 5 nuts I still don't get the axel out. I checked on my chargers 8 3/4
and that one has a locking ring to losen first but this one hasn't. The play, which you can't adjust is 0,06-0,08 inch. How do I get the axle out?
Logged
Belgium Cuda
Full Member
Re: 3rd member swap
Reply #14 on:
May 24, 2008 - 08:38:09 AM »
Got it out by putting the drum reversed on and pulling, this is how it looks. Not like in the manual for a -70 Cuda.
Logged
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
3rd member swap
