3rd member swap
Author Topic: 3rd member swap  (Read 2883 times)
Re: 3rd member swap
« Reply #15 on: May 24, 2008 - 09:14:27 AM »
Looks like the drivers side axle, I believe the passenger side has the adjustment screw to set end play
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: 3rd member swap
« Reply #16 on: May 24, 2008 - 09:58:50 AM »
Driverside had the adjuster without lockingdevice, play was 0,15 inch with other side out.
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: 3rd member swap
« Reply #17 on: May 24, 2008 - 12:09:18 PM »
3rd member is out, No Oil!!!!!!!! I have tried 2 years to get this car Ok, I hope this is the last issue. I see it says 3,23 on the ring but when
I tested it before by turning the driveshaft 2 turn and check  the turning of the wheels I got it to be around 4,9-5. That method works for all
my other cars, how can that be?  :banghead:
Re: 3rd member swap
« Reply #18 on: May 24, 2008 - 03:09:02 PM »
Everything back together, what a difference! Before when tranny went in third it felt like the car was going to brake in 2 but now you don't hear the rear anymoore.  :bigsmile:
Re: 3rd member swap
« Reply #19 on: May 25, 2008 - 01:47:56 AM »
 :2thumbs:, the the two tires do not turn at equal speed any ratio calculation will be out to lunch
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: 3rd member swap
« Reply #20 on: May 25, 2008 - 08:58:26 AM »
that will not have the center pin , it has or had buttons as it is a clutch type sure grip
 I would say it is not in OK shape it has surface rust on virtually all of the teeth & may be throuigh the case hardening , you may need a set of gears
question ?
so how do you get the buttons out ? (remove them)
thanks
Go Fast & Have Fun...
Re: 3rd member swap
« Reply #21 on: May 25, 2008 - 11:45:20 AM »
usually they fall out & disappear , is there an 1/8 hole through the center pin rigth now ?
    • THE DODGE BOYS
Re: 3rd member swap
« Reply #22 on: May 25, 2008 - 12:37:49 PM »
looks like it  but i am not sure  :dunno: I will check  if so do I need to drive the center pin out?
nivvy
Re: 3rd member swap
« Reply #23 on: May 25, 2008 - 12:40:44 PM »
I hope it works out for you. I couldn't imagine driving with 4:88's.   :eek7: You must redline at 40MPH.  :lol:
 :scared:
Re: 3rd member swap
« Reply #24 on: May 26, 2008 - 02:18:43 AM »
no the center pin stays in place , just remove the buttons
