Bare with me as I try to explain the best I can
68 440 automatic crank. The end was drilled deep, but not prepped for a 4 spd from the factory. So I bought the bearing that fits in the flange. All seems ok but with these comments, so give me your imput
If I start my car in neutral , it will surge forward maybe a half an in, maybe
As I drive my car in any given gear, up shifting or down shifting, I can hear a whining noise. But not in neutral setting still
I was wondering if maybe there is a slight chance the noise might be that the trans input shaft might be touching the bottom of the hole in the crank. Not enough to really keep the shaft engaged when the clutch pedal is down, but maybe enough to cause some harmonics throughout the drive train
Is it possible? I am pulling the trans pretty soon to put a better clutch in it and reseal the trans. Thought I may run a file over the snout end. I am thinking I should see some kind of sign of bottoming out.
Or maybe I have a bearing going out. I dont know
