Author Topic: 4 spd noise question  (Read 3128 times)
Re: 4 spd noise question
« Reply #15 on: June 01, 2008 - 02:10:04 AM »
Does the sound become louder when cornering? Just a thought, wheel bearings  :dunno:
If the crank is touching the input shaft shouldn`t there be noise only when you activate the clutch?
Didnt see no scars or marks on the imput shaft today. When opening the trans up, we didn't see no bad signs of wear or odd wear patterns, the bearings in front and back felt tight, just didn't find any extra play anywhere. Pilot roller bearing looks as new.  I think I heard a drivers wheel bearing making noise, the 410 sure grip I know makes noise to some degree. So were going to get the flywheel resurfaced tomorrow, and put it back together. I am going to install a 355 sure grip before it comes back off all the jack stands. I just had all new bearings and seals installed in the 355's but have to re assemble everything this week. I will keep everybody posted.  Thanks for working with me on this . Time will tell. Maybe the gear lube was a little low.
« Reply #16 on: June 01, 2008 - 11:27:29 PM »
Well, I got the new clutch in. Works great. Pedal is a little hard for my left foot being bad, but the fun over rides the pain.  The transmission didn't seem to make any more noises after we started it back up and test drove it. It all seemed to work great. So I don't understand why the noise was there.  But glad it's gone. 15 bucks to turn the flywheel.
A very special thanks to sleepychallenger  (drew)for dropping by for the weekend to give me a hand and also thanks to Clinton  (JACKSBOYS) For helping me out. Clinton even finished running my washer squirter hose for me.  Such a great gang we have here. The guys are on their way back home now. Wating on them to call and check in.
Once I do new axles bearings and install the 355's, I believe the car should be a lot quieter.  Is quieter a word?   :bigsmile:  It should be road worthy for long trips.
The clutch and pressure plate I used was a ram Power Grip. It has buttons on one side and regular pads on the other. Ram part number Ram-98773 My car seems to like it, and it doesn't chatter and hooks up really good. We'll see in the long run
