Author Topic: Fish out of water!!!  (Read 1309 times)
Offline cudadave72
  • you motorboatin sob!!!
« on: May 22, 2008 - 10:15:43 AM »
After nearly a year of owning the Cuda I finally got the chance to get it up on the Dyno. My good friend owns PRO-Dyno here close to Charlotte but the only problem is that his shop caters largely to the Ford/Mustang crowd. I just happened to pick a day that his shop was loaded with Cobras including a couple of badass 07/08 Shelby GT500s!! Anyways I had alot of fun and the car turned out awesome # considering I have yet to tune the car (last night was just base line pulls) and was very lean up top and the timing was turned down. I am going to make a couple of changes this week and hopefully will be able to pull an extra 20 to 30 hp out of it!! The final #s were 399 rwhp (it kills me not lie and say 400!! :pullinghair:) and 393tq though the 727 with a 4000 stall! This was on a Dynojet 248c and those #s are std. I'll post the dyno sheet soon. In the mean time here are a couple of pics!!
PS. There were at least another 1/2 dozen cobras (mostly 03/04) sitting outside!!!
« Last Edit: May 22, 2008 - 10:27:28 AM by 72cuda416 »
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline HemiOrange70
Re: Fish out of water!!!
« Reply #1 on: May 22, 2008 - 12:07:36 PM »
Theose fords were outside cause they were scared of your cuda    :bigsmile:    Should of unbo;ted your mufflers then over 400 hp
« Reply #2 on: May 22, 2008 - 01:18:30 PM »
Vry Nice
 the Dynojet does read higher #s than the Mustang Dyno I test on
Offline cudadave72
« Reply #3 on: May 22, 2008 - 02:40:08 PM »
Vry Nice
Thanks! :2thumbs: Yeah its known that Mustang Dynos read low. Not too many around here. Being here in NASCAR country I know that most teams use Dynojet, in fact Pro-Dyno has rented theirs out to a couple of teams before. Just curious to what combo you run and what it put down?
« Last Edit: May 22, 2008 - 03:16:28 PM by 72cuda416 »
Offline loco340cuda
« Reply #4 on: May 22, 2008 - 04:45:53 PM »
72cuda416, what your combo?
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Offline cudadave72
« Reply #5 on: May 22, 2008 - 05:43:10 PM »
70 340 block, stroked to 416 cuin, eagle crank and rods, ross pistons, Edlebrock heads ported, Victor 340 intake, Demon 750 carb, 555 solid lift cam (wish I knew more about the cam, it was in the car when I bought it) Mopar perf distributor, MSD 6AL, TTI step tube headers, TTI full 3 inch exhaust w/x pipe, built 727 tranny w/ PTC 4000 stall and transbrake, 8 3/4 rear end, 3.73 gears, 5/8 studded axles.
« Last Edit: May 22, 2008 - 05:49:59 PM by 72cuda416 »
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #6 on: May 24, 2008 - 04:39:29 PM »
Way to go 72cuda416!  I am sure after you have her al tuned in it will feel good to say 400+  :bigsmile:
Your Cuda looks great by the way.
Offline MOPAR-or-NoCar73
« Reply #7 on: May 24, 2008 - 05:10:05 PM »
Nice :2thumbs: Just out of curiosity, do you know the numbers that some of the cobras put down?
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #8 on: May 25, 2008 - 06:32:50 AM »
Nice dyno #s!   I would be afraid to put my car on a dyno!!!  :-[
How did the Cobras do?  Mustang Cobras or 427 Shelby CObras (The 2 seater deals)?  :dunno:
Offline cudadave72
« Reply #9 on: May 28, 2008 - 03:42:58 PM »
Thanks guys and gal(s) ;)! I wish I could say that the Cobras were afraid of the 'Cuda but the truth of the matter is that an 03/04 Cobra puts down 365 to 380rwhp straight out if the box. Ones with simple bolt-ons and a ported stock Eaton blower can make 550rwhp!!! Swap the Eaton for a Whipple or a Kenne-Bell and watch those #s jump to 650 to upwards of 700rwhp :22yikes:!! The one in the pictures on the dyno is a good example of a typical bolt on car and it laid down 525hp to the tires with a hand ported stock Eaton. The new Shelby GT500 is a bad mother too!! Swap out the stock blower for a Whipple and that bad boy can put down right at 800rwhp on a race tune. There was one GT500 that they dyno'ed that had a Whipple and a small shot of gas that exceeded 900 to the tires :worshippy :worshippy To bad it puked its guts out shortly afterwards. :puke: I guess its time to tell you guys that I own a performance shop that specializes in Ford high performance. We deal heavily in the late model SVT vehilcles being well known for our Lightnings and 02/03 Harley Davidson F150s. I have built several 10 second Lightnings and 11 second H-D F150s. We are currently moving in to the Cobra market. I actually sold my Lightning and a 93 LX mustang w/ a 408 stroker to buy the 'Cuda. To the Cuda's defence it is set up to get down the track and will e.t. with bolt on Cobras with more than 100 plus more rear wheel hp. I know this for a fact, my head mechanic Adam owns an 03 Cobra that lays down 550rwhp and on a full set of slicks and skinnies runs consistant 7.20s @ 100mph in the 1/8 mile (its best is a 7.06). The Cuda has laid down a best of 7.26 @ 95mph 1/8 mile on a set of drag radials! With a full set of slicks and hooking up the transbrake I feel it should boogie on down.  :2thumbs:
« Last Edit: May 28, 2008 - 09:31:19 PM by 72cuda416 »
« Reply #10 on: May 28, 2008 - 08:15:44 PM »
Nothing wrong with Cobras IMO.  I went to the Tasca Ford Mustang show last year and Bob Tasca Sr. and Carroll Shelby were there along with John Force.  Lots of Shelby Mustangs there, new and old.  Very cool!  :grinyes:
