Author Topic: 1970 318 stocker tune up trouble shooting  (Read 1169 times)
Alaskan_TA
« on: May 23, 2008 - 11:43:51 PM »
Hey guys,
I have not tuned a 318 for close to two decades now. A pal of mine is having this problem with my car;
"It's a bear to get started, even after forcing the butterfly closed, but once it's warmed up it purrs like a kitten in Park.
 But once in gear, the idle is really rough."
Details on the car;
1970 Coronet
318 with original carb.
Hose from heat riser is missing.
The car is in Colorado, but it came from Kansas, so possible alitude thing relating to fuel mixture?
The choke sounds like it needs to be adjusted per his description, what else should I consider / be prepared to check when I finally get to see it in person?
I may switch it to electonic ignition at some point, but for now no performance modifications are planned
Thanks!
Barry
Offline LAA66
Re: 1970 318 stocker tune up trouble shooting
« Reply #1 on: May 24, 2008 - 12:10:26 AM »
 Maybe Low compression. :-\
Offline CrazyPete
« Reply #2 on: May 24, 2008 - 10:14:09 PM »
id say its a given the carb needs work id just rebuild it and your problems would be gone  :2cents:
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
Offline ntstlgl1970
  • T a c o c a t
« Reply #3 on: May 24, 2008 - 11:47:34 PM »
as you mentioned, being in Colorado may make things a little tougher to tune. Denver at 7k feet? Stock carb is a two barrel? is it the B+B 2 barrel? I always thought those were easy to tune since you can adjust the metering rod rise and accel pump easy once the top access plate is off. Probably the exhaust crossover is plugged with carbon which doesn't help the cold warm up at all. I agree with Crazy Pete, plan on rebuilding the carb and replacing some vacuum lines.
« Reply #4 on: May 25, 2008 - 02:09:27 AM »
Hard to start is a choke issue either to rich & the pull off is opening the choke or too lean as the choke is not coming on properly
 rough idle could be vacuum or fuel leaks , tighen the screws on the carb make sure vacuum hoses are sealing , could have bad plug wires or plugs as well
 more ign advance will help both strating & idle in gear
Alaskan_TA
« Reply #5 on: May 27, 2008 - 09:27:25 PM »
Thanks guys!
I picked up new plugs today and I ordered a rebuilt carb and plug wires for it.  :thumbsup:
« Reply #6 on: May 28, 2008 - 01:41:23 AM »
tighten all the bolts & screws on the intake & carb as well
Alaskan_TA
« Reply #7 on: May 28, 2008 - 09:56:42 PM »
Will do, thanks Neil!
