Author Topic: dynos ?  (Read 533 times)
Offline 440mike
dynos ?
« on: May 24, 2008 - 12:27:19 AM »
So i took my car to a dyno day and was alot of fun.
does anybody no how much different it should be from a engine kind of dyno ?
i lost hp from when just the engine was dynoed when i bought it is that right ?
my boss said it can vary from 15-22 per cent depends on the cars trans ?
Offline NoMope Greg
Re: dynos ?
« Reply #1 on: May 24, 2008 - 12:39:32 AM »
Your boss is correct.  An engine dyno measures tq/hp at the flywheel - what the engine is capable of putting out.  A chassis dyno, what you had your car on, measures how much of that gets to the ground.  The losses are mostly frictional losses - parts rubbing on each other, the power necessary to move those parts through their lubricant and to move the lube itself.  You experience it as trans/rear-end/tires getting hot.  A manual trans has less frictional loss than an automatic (no auto trans fluid to pump inside a manual trans.)  That's why manual trans cars are typically a little quicker than autos, all other things being equal.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline Changin Gears
Re: dynos ?
« Reply #2 on: May 24, 2008 - 07:36:25 AM »
During a tuning session once on a chassis dyno I was wondering the same thing.  So I tried back to back pulls in 3rd and 4th gears (with a 4 speed).  Lost 65 hp in 3rd - about 10%.
« Last Edit: May 24, 2008 - 07:46:10 AM by Changin Gears »
