Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Anything special about rebuilding a Mopar engine?
« previous
next »
Print
Pages:
1
2
Author
Topic: Anything special about rebuilding a Mopar engine? (Read 2030 times)
matt63
Sr. Member
Re: Anything special about rebuilding a Mopar engine?
Reply #15 on:
May 27, 2008 - 09:49:29 AM »
Mopar big blocks and small blocks have many differences and each has it's critical steps you can't miss. Paying special attention to the weak points will make for a more trouble free engine. What engine are you doing?
Logged
Matt in Edmonton
'68 Valiant
moper
Resident
Reply #16 on:
May 27, 2008 - 12:27:10 PM »
If the guy is good, not just good at chevy engines, he will have no trouble getting the mopar right. If he is good at chevies, then find a shop and pay them. They do the same things, in different ways. there's at least 6 ways I can think of a Chevy experienced assembler (note I didnt say builder) can mess up and cost you money because they only know how to put a chevy together, as opposed to being an engine builder. And the commetns on cams, you guys are funny...lol. You really are.
Logged
jeryst
Resident
Reply #17 on:
May 27, 2008 - 08:24:10 PM »
The motor is a 73 340.
I am planning on having a machine shop boil the block and install the cam bearings, freeze plugs, etc.
Then we were going to do the rest.
Logged
matt63
Sr. Member
Reply #18 on:
May 27, 2008 - 09:26:37 PM »
Small block oil pan gaskets aren't the best so take extra care here unless you like leaks. You can get a timing chain tensioner now for these which I installed on my 408 stroker. Since they oil the top end/rocker shafts thru 2 of the cam bearings it is very important that the oil holes in the cam bearing line up properly. I think this is already mentioned. There are some other mods for hi-po engines of which some are outlined in the book mentioned below.
Logged
Matt in Edmonton
'68 Valiant
LAA66
Sr. Member
Reply #19 on:
May 27, 2008 - 11:58:58 PM »
Seems to me there was a recommendation about enlarging the oil passages from the cam to help feed the rocker assembly's.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #20 on:
May 28, 2008 - 01:58:06 AM »
I wouldlook for a 318 steel truck crank to put in it & have the rotating assy rebalanced , it is far better to have a neutral / internally balanced engine
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
