Author Topic: problem 727 in second  (Read 1249 times)
Offline tvacuda340
  • F1A procharger 422 small block
« on: May 25, 2008 - 05:55:32 AM »
need some helps !
 It is a rebuild  727 with manual valve body
I can place it in first =oK  but in second nothing is happen !!, in drive ok,  neutral ok ,revers ok, and park ok ,
shifter link is all ok ( I tjek it by shift it by hand !)
 can it be the kickdown servo /band ?
or ?
I will soon  :horse:  that transmission !!
thanks
Offline tactransman
Re: problem 727 in second
« Reply #1 on: May 25, 2008 - 09:26:53 AM »
Give more history on it, (was it working OK then it started doing this or is it a fresh rebuild first time ran etc.)
Terry-tactransman
Union, Mo.
Offline tvacuda340
« Reply #2 on: May 25, 2008 - 10:36:12 AM »
it surepose to be fresk rebuild ,got some problems with this transmission  :banghead:!
the old  stock valve body did work .nothing where happen when I put in drive or other gears !  so I buy a new cheeather manual valvbody
 now  it is  working but not in second
the shift Is Ok from low to drive ,and also from drive to neutral or revers
only when place the shifter in low and  and shift to second nothing is happen then shift it to  drive then is shift to drive  ???
Offline tactransman
« Reply #3 on: May 25, 2008 - 11:48:36 PM »
Are you trying this out on jack stands?(tires off the ground) If so,you have to watch the Cheetah VB's because you will not feel a 1-2 shift in the air but it will be fine on the ground while driving the car.
Terry-tactransman
Union, Mo.
Offline tvacuda340
« Reply #4 on: May 26, 2008 - 05:12:46 AM »
OK !...
 I do this on jack stander , I will try on the floor
 let you know
thanks !!!
Offline tactransman
« Reply #5 on: May 26, 2008 - 06:21:06 PM »
 :popcorn:
Terry-tactransman
Union, Mo.
Offline tvacuda340
« Reply #6 on: June 03, 2008 - 02:05:44 PM »
hallo tactransman
sorry for late repley ( JUST BLOWE MY HEAD GASKET..... to much boost )
but it is working  .. like you say on ground it is shifting right now
thanks
Offline tactransman
« Reply #7 on: June 03, 2008 - 02:07:32 PM »
 :2thumbs:
Terry-tactransman
Union, Mo.
