Going Bracket Racing Memorial Day! (Video's)
Author Topic: Going Bracket Racing Memorial Day! (Video's)  (Read 2705 times)
Swedefish
Re: Going Bracket Racing Memorial Day!
« Reply #15 on: May 25, 2008 - 01:29:58 PM »
Good luck and have fun. Show those guys what Mopar power really is about. :2thumbs:
Looking forward for the video
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #16 on: May 26, 2008 - 04:58:36 PM »
I should be running everyone down in that class....  :scared:
You're just lucky Im not there!!!   :aarg:
Good luck bro!  I will be riding with you in sprit!     :2thumbs:
Don
Post # 1973 same year as the cuda!
Member Since January 14, 2002
nivvy
Re: Going Bracket Racing Memorial Day! (Results!)
« Reply #17 on: May 26, 2008 - 07:02:03 PM »
Well the weather was about 80* and yes I was nervouse cause I never competed before.....  :scared:
I left the sway bar hooked up and didnt have the secondaries on the dominator opening at  1 to 1 shifted at only 5800 except for the second pass I didnt see the shift lite cause of my helmet and hit the chip at 6700  :scared: the crappy 60 fts are probably from the sway bar for 1 reason and i had trouble getting in the groove...
And yes with no cage 11:49 and quicker I got the  :nono:
All in al it was a blast and will be posting some you tube videos when loaded.......  :2thumbs:
93 pump gas
ET streets
All Motor
Pass1
R/T    .071
60     1.975
330    5.36
1/8    8.00
MPH   93.85
1000  10.24
1/4    12.09
MPH   120.61
Pass2
R/T    .009
60     1.751
330    4.79
1/8    7.34
MPH   94.39
1000  9.58
1/4    11.44
MPH   122.43
Pass3
R/T    .018
60     1.783
330    4.830
1/8    7.36
MPH   96.70
1000  9.55
1/4    11.38
MPH   124.22
And Yes I got number one qualifier wit R/T and go to watch all my competitors as I got to go last with a bye run....  :bigsmile:
My car weighed in at 3790 with me in it... At that MPH/ weight I would like to see 10.80's  :2thumbs:
« Last Edit: May 26, 2008 - 09:09:14 PM by StRoKer »
Offline Oldschool
  • Member Since 9-05-06
« Reply #18 on: May 26, 2008 - 07:09:25 PM »
Great number Stroker...    :ylsuper:   Nothing like taking a strong Mopar down the 1/4 mile at full throttle..    :grinyes:  I know you had a blast and I look forward to the vid....      :cheers:
« Last Edit: May 26, 2008 - 07:27:40 PM by Oldschool »
Ken  --  In Georgia
nivvy
« Reply #19 on: May 26, 2008 - 07:19:46 PM »
First video I raced a mustang that went 20's ............  :eek4:
when i did lose in the brackets at least I lost to a 14.75 dodge dart.... I redlit though and lost.... i pushed a valve cover gasket anyway and I was done.....  was fun.......  :cooldancing:
« Last Edit: May 26, 2008 - 08:28:52 PM by StRoKer »
Offline vinb
« Reply #20 on: May 26, 2008 - 08:50:33 PM »
Glad to see you made a few good runs on your 1st outing..
Now if you can get that thing to 60' , (1.45 to 1.50) you'll probably go some 70's..
What kind of rpm's did you leave at and what where your shift points & trap rpm's?
Like I said before, you need to a get a Dana in there and leave like 3500 to hit that tire hard...
124 mph not bad in a 3800 car with a small tire..
Bet you can't wait to go out next week....
(little info if needed, my good friend has a chassis shop within walking distance up the street if you need anything done )
DRC Race Car Products / John
nivvy
« Reply #21 on: May 26, 2008 - 08:59:05 PM »
I was footbraking at about 1800 rpm... when you see the video I was pushing through the beams...... Im definately changing converters...... and dana 60 soon enough......  :bigsmile: I was having alot of trouble getting in the groove as well... was fun for my first bracket race...
Offline 422STROKER
  • Member Since 6/3/06
« Reply #22 on: May 26, 2008 - 10:19:58 PM »
Great Job Stroker.  I guess You need a cage now.
I hope to make it to the strip this year.
Tom :2thumbs:
Tom
Offline 67vertman
  • Member since 9-23-2005
« Reply #23 on: May 26, 2008 - 11:43:24 PM »
What was your traction like during the first 60 ft?
If you were spinning the tires a little, it could account for the slower 60 ft times.
You may want to drop the air pressure a couple of pounds or add so 90/10 shocks to get better weight transfer.
Overall, very impressive. With some pretty respectable times to boot.
  • Pearl Harbor, HI
    • C-C.com
« Reply #24 on: May 27, 2008 - 02:57:21 AM »
Man that is awesome, just seeing the pics that you took make me WISH I was there with you!  I bet you had a blast!
Don
nivvy
« Reply #25 on: May 27, 2008 - 04:06:54 AM »
Shocks are 50/50 rear and 90/10 front I have got 10.90's before but the bracket race thing mad me somewhat nervous... yea Ive got alot of fine tuning to do... and being a better bracket racer for sure though... still would like to dial to consistant 10.80's....
obviously traction sucked with a 1.78 60ft  and 11.38 e.t.  ... oh well the bracket racing thing was fun I guess... I coudnt dial anything under a 11.50 cause of the no cage thing...I am going to a track rental next week to try and dial her in....
« Last Edit: May 27, 2008 - 04:14:33 AM by StRoKer »
nivvy
Re: Going Bracket Racing Memorial Day! (Video's)
« Reply #26 on: May 27, 2008 - 04:18:52 AM »
Btterys went dead on the 3 pass... oh well...
Pass 1
Pass 2 Hit the rev limiter in 2nd and almost went into the grass... :pullinghair:
« Last Edit: May 27, 2008 - 04:30:34 AM by StRoKer »
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #27 on: May 27, 2008 - 04:34:00 AM »
cool thanks for the video.  :woo:
Will you be installing a rollcage now?
 & Trans break next also?
Go Fast & Have Fun...
nivvy
« Reply #28 on: May 27, 2008 - 04:41:33 AM »
converter change and dana 60 is first on the list...
  • Pearl Harbor, HI
    • C-C.com
« Reply #29 on: May 27, 2008 - 04:56:26 AM »
SWEET!!!   :ylsuper:
Don
