Author Topic: Siamese-Bore  (Read 1051 times)
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Siamese-Bore
« on: May 25, 2008 - 12:02:06 PM »
What does it mean when applied to an engine block?
Cuda Guy
Member Since January 14, 2002
Re: Siamese-Bore
« Reply #1 on: May 25, 2008 - 12:03:46 PM »
The cylinders are side by side touching each other.  My 499 mega block is that
Re: Siamese-Bore
« Reply #2 on: May 25, 2008 - 12:10:37 PM »
this makes the block stiffer & helps with power but limits the cooling as wtaer cannot pass between the bores , I have no heard of Mopars overheating due to this but Chevs always used to with Siamese bore blocks
  • Pearl Harbor, HI
    • C-C.com
Re: Siamese-Bore
« Reply #3 on: May 26, 2008 - 10:02:53 AM »
Thanks guys!  I just see all these new blocks for sale and they have that style bore.
Don
Offline Aussie Challenger
Re: Siamese-Bore
« Reply #4 on: May 27, 2008 - 06:26:54 AM »
  Ask any chevy guy what they have to do to try and cool the siamesed blocks. Drill extra holes in the block and head, and I have also seen a couple of blocks with extrenal piping just to try and keep it cool and that was in a street car.
   :screwy:  Bores need to be kept cool especially around the top, if the 2 centre bores are joined together it creates a hot spot which in turn will distort both bores offering poor ring seating.   :22yikes:
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Siamese-Bore
« Reply #5 on: May 27, 2008 - 09:04:24 AM »
Just curious, did the Pontiac 301ci (4.9L) engine have siamese bores also?  Someone a looong time ago mentioned this to me and they said that was one of the reasons that not a lot of hi-perf. stuff wan't available for that engine?  I dunno...  :dunno:  :clueless:
Re: Siamese-Bore
« Reply #6 on: May 27, 2008 - 08:14:38 PM »
The mopar mega blocks with the siameese bore has over a 1/2 thick deck to it. Our big blocks came with long strokes so it has deep walls.  You really wont see a big issue with these blocks.  Or atleast I havent
  • Pearl Harbor, HI
    • C-C.com
Re: Siamese-Bore
« Reply #7 on: May 28, 2008 - 03:11:54 AM »
So I take it these blocks are good for cars that are on the street?
Don
Re: Siamese-Bore
« Reply #8 on: May 28, 2008 - 10:53:16 AM »
the Mopar ones seem to be fine possibly the Mopar s just have better cooling design & accomadate the siamese bore better
