Challenger SE Finish Panel & Trunk Lock Q
Author Topic: Challenger SE Finish Panel & Trunk Lock Q  (Read 1333 times)
Offline CraigRTSE
« on: May 25, 2008 - 12:44:14 PM »
Hi,
Does the trunk lock cylinder mount over the SE finish panel (going through the round hole)?  Or does it just mount to the car body and the filler panel goes over it?  Would seem to make sense if it went through the hole in the filler panel, but it doesn't fit.  Unless I have the wrong lock cylinder (it mounts in place with a clip).  Any insight would be helpful.  Thanks.
440-4, 4spd, 3.54 Dana, 1 of 142
http://www.youtube.com/watch?v=qACNIBfhe0E
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: Challenger SE Finish Panel & Trunk Lock Q
« Reply #1 on: May 25, 2008 - 12:48:04 PM »
the paneel goes over the lock.  :screwy:
Go Fast & Have Fun...
Offline CraigRTSE
« Reply #2 on: May 25, 2008 - 01:45:21 PM »
Another reason that made me question it is from seeing this.  Thanks for clarifying.
« Reply #3 on: May 28, 2008 - 11:31:36 PM »
I agree the panel goes over the lock , someone must have modified the one in the picture to make the lock go through the panel , it would be a tight fit the distance on the lock from the face to the clip is short
Offline scf100
  • FAST LANE FOREVER!
« Reply #4 on: June 02, 2008 - 01:02:59 AM »
I agree with the above.......don't ask me how I know :stomp:
1970 Challenger R/T convertible 383…. 4-speed…3.91 suregrip
Triple Black
« Reply #5 on: January 30, 2009 - 02:55:43 AM »
OK I just checked my original finish panel , the hole is too small for the lock to fit through , the lock Has to go behind the panel just like the door handles
Offline RusTy/SE
  • Just havin' fun
« Reply #6 on: February 01, 2009 - 12:23:56 PM »
Exactly. once the finish panel is installed, it's attaching hardware will snug it up to the tail panel.
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
