Author Topic: Seat track repair  (Read 3687 times)
Offline CrazyPete
Seat track repair
« on: May 25, 2008 - 01:42:11 PM »
is there any good way to replace the studs on the seats and rebuild the seat tracks?  btw this is for front bucket seats outta my gran coupe
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
Re: Seat track repair
« Reply #1 on: May 25, 2008 - 11:56:21 PM »
Did this a couple of years ago on my '73 (many details elude me). I do remember removing one of the studs, they are pressed into a square hole. I just beat it out with a hammer, upon reinstall the stud did not want to stay until I ran a nut all the way down & tightened to pull it back into place.  The rollers & bearings in my guides were dry & not fully functional. Chiseling, scraping & scrubbing out the old dried out grease was the hardest part. I was missing a couple of ball bearings but replacements were found at a local bicycle shop. One of my rear rollers was flat spotted so I filed on it to try to make functional then installed in the front figuring there would be less pressure there. Painted & greased now smooth as butter.
Offline CrazyPete
« Reply #2 on: May 26, 2008 - 09:02:41 AM »
thanks for the feedback they still slide somewhat free so i may have an easier time and of course i have a few broken studs.      Thanks at least now i know whats ahead of me.
Offline ShelbyDogg
« Reply #3 on: May 26, 2008 - 10:55:26 AM »
I had a couple broken off too.  If yours don't have to be factory original, do what I did; I put a regular bolt in from the top and put a couple of tack welds around the head to keep it in place.
Offline CrazyPete
« Reply #4 on: May 26, 2008 - 07:57:36 PM »
 :thumbsup: that was my plan thanks
Offline LAA66
« Reply #5 on: May 27, 2008 - 10:22:32 AM »
 I cleaned mine up last year and noticed some rust on the bottoms near the studs. I concluded the spray from driving in the rain must have gotten through. Upon reassenbly, I applied silicone sealant at each opening before installing the washer and nut. :2cents:
« Reply #6 on: May 28, 2008 - 11:17:26 PM »
Dumdum around the bolt will keep it sealed as well
Offline CrazyPete
« Reply #7 on: May 29, 2008 - 07:43:34 PM »
what is dumdum?
Offline ShelbyDogg
« Reply #8 on: May 30, 2008 - 12:04:22 AM »
Maybe he meant bubble gum.   :bigsmile:
I figured a guy with a name like CrazyPete would have a brother named DumDum.
Offline larry4406
« Reply #9 on: May 30, 2008 - 05:58:59 AM »
dum dum also called thumb gum - go to the electrical isle at lowes/home depot.  it is a gray soft clay-like brick.  Brake a piece off, roll it into a snake, put it around the stud, tighten, it smashes and seals.  Similar in concept to plumbers putty.  Thumb gum is used in houses to seal penetrations thru siding (hvac line sets, hose bibs, cables, etc.)
Offline CrazyPete
« Reply #10 on: May 30, 2008 - 08:03:01 AM »
 :smilielol: funny stuff right there
oh yeah i know that stuff never heard it called that i actually got a little block of that stuff ill give it a try
