Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
speedo not working,replaced cable still not working. WHAT NEXT
« previous
next »
Print
Pages: [
1
Author
Topic: speedo not working,replaced cable still not working. WHAT NEXT (Read 1131 times)
geneo4116
Jr. Member
70 rt 383 auto blk/blk apprx 450hp
on:
May 26, 2008 - 09:12:37 PM »
what do i check next and how, could there be something wrong inside tranny, was working but jumping around alot, and finally quit all the way, so i ordered new cable and replaced but still not working
Logged
sleepychallenger
Guest
Re: speedo not working,replaced cable still not working. WHAT NEXT
Reply #1 on:
May 26, 2008 - 09:16:06 PM »
pull the cable and speedo. see if the needle moves when you spin the cable by hand. sounds like one of the plastic pieces in there might have busted
Logged
Alaskan_TA
Guest
Reply #2 on:
May 26, 2008 - 09:26:09 PM »
Pull the cable loose from the transmission first.
Once it is loose, push the inner drive cable up towards the dash to make sure it is seated all the way in the speedo.
Then re-attach to transmission & test drive.
It worked for me.
Logged
sleepychallenger
Guest
Reply #3 on:
May 26, 2008 - 09:42:51 PM »
good catch Barry.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
May 28, 2008 - 11:16:15 PM »
sometimes the speedo gear will strip put the car up on jack stands & run it in gear & make sure the speedo drive is turning or remove the drive with the rear jacked up & visually check the drive gear
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #5 on:
May 29, 2008 - 09:23:15 AM »
Just something else to throw out there...
You'll notice on the speedo gear houseing, that there are 3 sets of numbers. These numbers correspond to how many teeth the speedo gear has that you are useing. If for instance you are useing a 28 tooth gear, then the number range of 26-31 would be rotated to the bottom.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
CrazyPete
Full Member
Reply #6 on:
May 30, 2008 - 06:00:11 PM »
Pull the speedo outta the trans i had the same issue my cable broke i got a new one from the paddock installed it and it wouldnt work i messed around with it for about an hour. Said the hell with it drove it for a while with the speedo not working then one day i was doing the bolt tighting chore and decided to check the speeeeeedo gear and installed a new O-ring and bam it works. Needless to say i was shocked.
Logged
1970 Dodge Challenger T/A
http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak? No it's just sweat from all that HORSEPOWER"
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
