Author Topic: Eddy carb reccomendation  (Read 6603 times)
sleepychallenger
« on: May 28, 2008 - 01:09:39 PM »
For my almost stock 383. what eddy carb would you run. i am running a carter AVS right now and the hollys dont let me keep my factory air cleaner. I am still getting about 60 miles to half a tank   :eek2: i have put in the MP electronic ignition and adjusted my timing, checked for vacuum leaks, and i just dont know what else to do. i am thinking i might have a bad carb. i did get it off of ebay!!! it has been rebuilt twice. no change.  :feedback:
Offline arcticmopar
  • Yukon Canada
Re: Eddy carb reccomendation
« Reply #1 on: May 28, 2008 - 05:40:42 PM »
Well the 71 383,s came with a holley (a shorter single inlet style) so a stock air cleaner should fit them. :clueless: If it is stock a 625cfm carter or 600cfm EDDY should suffice but add headers, good dual ex and even a mild cam then a 750 EDDY should be better. 60 miles to half a tank seems thirsty but what gears and tranny do you have? mostly city or hiway miles? :dunno:
 myself I have forgot what I get to a tank ??? just keep an eye on the guage.lol. I,m running a 800cfm EDDY on my warmed over 383 because I know I will be going to a stroker 383 in a couple of years and didnt want to buy a diff carb just a few years later.
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
sleepychallenger
« Reply #2 on: May 28, 2008 - 05:46:56 PM »
i am running 323 gears with a stock 727 tf. the 383 has a hemi grind cam and a .030 overbore. thats it. MP electronic ignition.... in town driving but in town is about average of 50 mph.
Offline GoodysGotaCuda
« Reply #3 on: May 28, 2008 - 08:06:21 PM »
650 thunder avs in my opinion.
1976 Dodge Warlock
Wheel & Tire Specs:Link
sleepychallenger
« Reply #4 on: May 28, 2008 - 08:41:57 PM »
are they pretty much bolt on and go?
nivvy
« Reply #5 on: May 28, 2008 - 10:27:48 PM »
throw ALL edelbrocks in the trash .....   :2cents:
« Reply #6 on: May 28, 2008 - 11:50:28 PM »
the Holleys had provision for A/C on some models , not sure what the issue is with yours but it could have the wrong metering block gasket in it , they take a different gasket
« Reply #7 on: May 29, 2008 - 12:37:18 AM »
Maybe for your engine. But for stock/mild/cruising engines, they are extremely user friendly, easy to tweak and tune, and are very reliable. There is a place for them...
Drag car? No
Mild Street/Car Show Cruiser/Stock? Absolutely
1976 Dodge Warlock
Offline DanGoodman
  • MOPAR OR NO CAR
« Reply #8 on: May 29, 2008 - 12:43:21 AM »
Drag car? No
 :iagree: :2thumbs:
MOPAR FAMILY
nivvy
« Reply #9 on: May 29, 2008 - 04:23:46 AM »
Drag car? No
I just tried em out and had no luck thats all..........  :lol2: my original 2 4 barrel setup was pretty though...
Offline dwbiggs
« Reply #10 on: May 29, 2008 - 08:16:01 AM »
Quote
« Reply #11 on: May 29, 2008 - 01:21:15 PM »
What 4bbls? I was lookin at that wiring   :bricks1: :icon16:
1976 Dodge Warlock
« Reply #12 on: May 29, 2008 - 01:27:28 PM »
if you have to use an Eddy use the 750 AVS thunder ,it is the best if that style carb
sleepychallenger
« Reply #13 on: May 29, 2008 - 01:57:18 PM »
thanks guys. if i had a holley that would let me keep my stock air cleaner i would probably use it. my gas mileage went down, i am getting about 130 miles to a tank. 18 gal tank. that is 7.2 MPG. What the heck.
nivvy
« Reply #14 on: May 29, 2008 - 02:40:03 PM »
man I only get 2.1 miles to the gallon in my 18 gallon tank.....  :scared:
goody the wiring has been cleaned up as thats an old pic  :smilielol:
