Chyro, this is why I think a 750 is something I would not bother with.
i am running 323 gears with a stock 727 tf. the 383 has a hemi grind cam and a .030 overbore. thats it. MP electronic ignition.... in town driving but in town is about average of 50 mph.
I used italics to high light the key area I thought of concern.
Now I'm also makeing this recomendation on a assumption that the OE poster may not be able to tune a carb well. Be it the case or not, the larger throttle bores can be harder to tune in. A smaller carb will be very responsive to throttle position, the engine will indeed pick up power with more cfm's, but not really use/need them until higher RPM's which seem not to be the case with low MPH speeds. With the 3.23 gears, even a small tire car will not turn alot of RPM's.
At 5,500 rpm's, a 383 will need about 600 cfm's of carb, at 6000 rpm's, about another 50 cfm's.
A lightly modified engine as his could use some more cfm for max performance, but I didn't think he was after that given the basic set up and low speeds he stated he drives at.
AVS 650 or Holley 670 would fit the bill IMO. But thats just it. An opinion.
