Author Topic: Eddy carb reccomendation  (Read 6606 times)
sleepychallenger
Re: Eddy carb reccomendation
« Reply #30 on: June 06, 2008 - 08:54:02 PM »
If I'm reading your timing #'s correctly and you have 51* AT IDLE with the vacuum advance connected, then you have it connected to the wrong port. It should be on the ported vacuum port which should have NO vacuum at idle. It is on the pass side of the front of the carb.
nope, 51* at rev up. 15 degrees at idle
Offline hemiken
« Reply #31 on: June 06, 2008 - 08:59:02 PM »
Hadn't checked the coil either. Points to electronic, I think there was a difference, can't remember
Hey Alan,
The coils are different buddy.  So it will need changing when Drew gets the chance. :2thumbs:
sleepychallenger
« Reply #32 on: June 06, 2008 - 09:00:51 PM »
Alan,
I put an eddy carb on and it runs better and is getting much better gas mileage. however, it changed up everything else that we did. i am just trying to get it to not ping now. i think i may have a bigger problem now. the rear end sounds like i am dragging chains. started hearing it when i got back from your place. will have to check
Hemiken,
which coil? i just upgraded to the MP electronic distribuitor.
« Reply #33 on: June 06, 2008 - 09:17:01 PM »
Makes me feel bad about your gears. I gave you a set and offered to install them before you left.....Come back :bigsmile:
I can also redo your timing.  does it ping with the vac line unplugged?
sleepychallenger
« Reply #34 on: June 06, 2008 - 09:20:00 PM »
dont think it would ping with the vacuum unplugged. will have to try that. i know you offered Alan, dont feel bad. I will figure something out. if it is the trans, it gives me more incentive to get the swap done sooner. if not, then i will probably be looking for a 323 or 355 suregrip chunck.
Offline hemiken
« Reply #35 on: June 06, 2008 - 09:23:19 PM »
Alan,
Hemiken,
If you guys just swapped out a points dizzy for an electronic dizzy and did not change the coil, you shopuld look at getting something like an MSD blaster 2 but when you order make sure you stipulate it is for electronic dizzy :2thumbs:
« Reply #36 on: June 06, 2008 - 09:24:51 PM »
I just built a 355 sure grip the day after you left :2thumbs:
sleepychallenger
« Reply #37 on: June 06, 2008 - 09:25:57 PM »
will do, thanks man. hope that helps. tomorrow is my last day in the states so i will probably order it when i get back
sleepychallenger
« Reply #38 on: June 06, 2008 - 09:26:34 PM »
well geez Alan, just a day late there huh  :roflsmiley:
« Reply #39 on: June 06, 2008 - 09:29:19 PM »
Got those clutch n brake pedals out now, and the rod that goes through the firewall
sleepychallenger
« Reply #40 on: June 06, 2008 - 09:31:02 PM »
when you wanna send them down?  :bigsmile: cant wait to get back and i havent even left yet.
sleepychallenger
« Reply #41 on: June 06, 2008 - 09:31:33 PM »
you feeling any better? i know you were hurtin the other day.
Offline hemiken
« Reply #42 on: June 06, 2008 - 09:33:45 PM »
I think you young blokes gave him a flogging :icon16: he was hurting after you guys were their.
sleepychallenger
« Reply #43 on: June 06, 2008 - 09:35:24 PM »
we just had more energy and ran him raggid. im sure he will survive. he is a sturdy guy   :poopoke:
Offline hemiken
« Reply #44 on: June 06, 2008 - 09:40:03 PM »
yea, he is built like a bull but has the heart of a Teddy Bear :grinyes: Just a little more recoupe time to get well hey buddy :2thumbs:
