Author Topic: No brake lights (again)  (Read 978 times)
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« on: May 31, 2008 - 09:26:07 AM »
Took the car and trailer out yesterday for a ride. When I got back I noticed it wasn't discharging a little as I backed into the yard. It usaly did when I hit the brakes. Now after checking fuses, lights, grounds, ect. I found everything works but the brake lights.
This has happened before so I checked the turn signal switch (again).  :( Another switch gone bad!!! :swear: It has to be the extra load of the trailer lights that keeps burning these things up.  :pullinghair:
I was thinking of installing a set of relays for the tail lights. To take the load off the switch. Kind of like what some have done for the headlights. I have a good idea how to do the setup of the relays.
My questions are about the relays. What relays should I get? And will they hold up to the constant on/off of the brake light circut? Also do you even think it is a good idea?
Dave :wave:
« Last Edit: May 31, 2008 - 09:29:17 AM by purple1 »
Worlds first e-body trailer.    Severna Park, Maryland
Re: No brake lights (again)
« Reply #1 on: May 31, 2008 - 10:41:48 AM »
shouldn't hurt a thing as long as the relays are rated for the load.
30amp headlight relay @ $4.ea should do the trick, they are constant load when the headlamps are on.
http://www.partsamerica.com/productdetail.aspx?MfrCode=OPR&MfrPartNumber=A715&CategoryCode=3443
Offline purple1
« Reply #2 on: May 31, 2008 - 10:53:35 AM »
Thanks, I'm going to plan it out that way then. I hope this stops taking out that switch...
Dave :wave:
