Author Topic: lowering the front height  (Read 991 times)
Offline burrpenick
« on: May 31, 2008 - 11:42:35 PM »
My car sits a bit high in the front- maybe 1.5-2.5". It was suggested by a buddy to lower it some using the torsion bars. It appears to me that I needed to screw them counter clockwise to lower the car, so I started with about 3 complete turns on each side, will check to tomorrow after I have rolled it some. Did I turn them the right way and would that be enought turns?
Thanks, George
« Last Edit: May 31, 2008 - 11:44:28 PM by burrpenick »
GEORGE
currently Moparless
Offline hooD
  • detroit iron
  • Motor City Made Muscle
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Re: lowering the front height
« Reply #2 on: June 01, 2008 - 12:32:41 AM »
counterclockwise is the correct way to lower the car , 4 full turns will lower the car 3/4-1" typically , try 4 more & make sure you check the toe in when you find the ride height you like
Offline dwbiggs
« Reply #3 on: June 01, 2008 - 11:37:54 AM »
Make sure to go get your alignment checked after you lower it.
Offline GoodysGotaCuda
« Reply #4 on: June 01, 2008 - 01:18:09 PM »
I did my own alignment using at home gauges. I went down two rounds and didn't change specs for what its worth.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Aussie Challenger
« Reply #5 on: June 02, 2008 - 05:23:31 AM »
  The camber and caster will alter as well as the toe in, but don't forget to check how much room or gap is left between the bump stops, too little and the car will under steer badly as the suspension will not be working.   :working:
