Author Topic: trunk pan questions  (Read 1327 times)
Offline cudadave72
  • you motorboatin sob!!!
trunk pan questions
« on: June 01, 2008 - 04:49:38 PM »
The next big project for the Cuda is to replace the trunk pan. The car is super solid and this is the only area that need attention. That being said I am going to do this with the car intact. Only the center of the pan is weak, so what are my options. A one piece pan seams like a waste of money since it appears that I'll have to cut it up just to get it in. Should I buy a two piece or buy the one piece and cut it into sections. Also what removes the incorrect speckle paint that someone used to "cover up" the rust?? :2thumbs:
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline hemiken
Re: trunk pan questions
« Reply #1 on: June 01, 2008 - 04:55:27 PM »
It is pysically impossabile to fit a full pan like you may already know, the two piece would be the better solution unless your welding skills are good then i would suggest the mothod of cutting in half like you also mentioned.  No overlap of the panels this way, that is if you are after a 100% factory look of course.
The speckled paint may have to be ground off using a paint stripping abrassive wheel.
Post a picture of your trunk area if you do not mind so we can determine what would be the best methodology. :2thumbs:
« Reply #2 on: June 01, 2008 - 05:03:07 PM »
I would buy the 1 piece pan ,trim it down to the size of the area that really needs replacing , slide it in from the back seat even if you have to remove the X bracing & reweld it
just my  :2cents:
Offline hemiken
« Reply #3 on: June 01, 2008 - 05:05:30 PM »
Hey CP,
Good idea............. The X-brace would have the least amount of spot welds to drill out. :2thumbs:
« Reply #4 on: June 01, 2008 - 05:07:59 PM »
exactly :2thumbs:
Offline cudadave72
« Reply #5 on: June 01, 2008 - 10:17:20 PM »
I'll post a pic tommorrow. Not much to look at. Its not horrible but not great either. The speckle paint is the biggest pain that I see as I would like to paint the trunk back to factory color when its finished. I thought about paint stipper (aircraft stripper) however one screw up and there goes my paint job!!! :banghead: :bricks1:
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #6 on: June 02, 2008 - 01:11:25 AM »
Yes do the 2 pans the one piece is a pain in the butt to fit my husband put one into a challnger this week and what a pain.
michele
Offline DMZ73
    • http://www.pbase.com/dmz73/
« Reply #7 on: June 02, 2008 - 11:54:26 AM »
I used the complete pan and trimmed it to fit, only cutting along the edge of the frame rail.
I cut from the tangent of the frame rail to the forward edge lapp-joint:
< http://www.pbase.com/dmz73/image/88616958 >
Heres how I trimmed my trunk pan:
< http://www.pbase.com/dmz73/image/88616960 >
I managed to find a way to get the rearward edge flange under the tail panel, since I had rust really close to the seam, it warranted replacement.
< http://www.pbase.com/dmz73/image/88616965 >
It was pretty easy overall. i definitely did not need to go all the way our to the trunk extensions.
hope this helps.
Dan
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #8 on: June 02, 2008 - 12:05:14 PM »
I would buy the one piece and trim it to fit. The two piece from what I have heard doesn't fit and the lines are wrong. Long term I think you would be happier if you spent the extra money. I know I am.
1996 Dodge Viper GTS Coupe
Offline Lunchbox
« Reply #9 on: June 02, 2008 - 05:43:32 PM »
Isn't the seam for the two piece pan go right through a formed rib in the middle? That would be a pan to grind the welds down. I like the idea of if you do cut a one piece you can put the seam right over the fram rail, then you would only have to grind the weld on one side of the panel.
Lunch
Offline FY1Cuda
« Reply #10 on: June 03, 2008 - 01:03:11 AM »
I would do a two-piece.  I welded and grinded mine to the point where people think I installed a 1-piece.  Had I known they even offered a one-piece I would have gone that route since I had my tail panel out.   :2cents:
Offline cudadave72
« Reply #11 on: June 03, 2008 - 12:26:28 PM »
Removing the x brace is a great idea but a little beyond what I intended on doing. Honestly the pan could wait untill I do a full restoration which I'm planning on doing in the next 3 to 5 years (its in great driver shape right now). What I am tring to do is a little project here and there keeping the car drivable that way when it comes time to paint it all I have to do is break it down and put it right back together. My fear is tearing the car apart and getting too busy or something happen where I never get it back together. I've been there before, had a car 95% done and got too busy to finish it and took a beating when I sold it. Luckly that was just a Camaro! :rofl:
