Author Topic: Front Drums changed to Wilwood Discs  (Read 1166 times)
Offline Madmax440
« on: June 01, 2008 - 07:03:42 PM »
Converted those ole brake drums over finally and I have to say that their product was very easy and basically just straight bolt on.
Offline GoodysGotaCuda
Re: Front Drums changed to Wilwood Discs
« Reply #1 on: June 01, 2008 - 07:04:40 PM »
Looks great! Can i ask how much that conversion cost?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #2 on: June 01, 2008 - 07:09:41 PM »
Anything different with the wheels like the back spacing?  :clueless:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline Madmax440
« Reply #3 on: June 01, 2008 - 07:45:27 PM »
I got it from Magnumforce and with everything listed below it came to $1,243.95. The toughest part of the job was the new Master Cylinder, because as we all know has to be done from under the dash. No changes in reference to backspacing though.
Mopar Front Disc Brake Kit B & E-body drum spindle (Drilled Rotors, Polished, Add flex lines, Add Tandem Master diecast, Add pushrod and rod end, Add master cylinder adapter) - WIL140-2721.
« Last Edit: June 01, 2008 - 07:47:35 PM by Madmax440 »
« Reply #4 on: June 01, 2008 - 07:51:39 PM »
what size rotors did they come with?
1976 Dodge Warlock
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #5 on: June 01, 2008 - 10:42:11 PM »
 :wow:
Member Since January 14, 2002
Offline BIGSHCLUNK
« Reply #6 on: June 01, 2008 - 11:05:54 PM »
Go and whoa... a great combination.  :thumbsup: I'm sure you'll find cruisn' allot more fun!  :burnout:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #7 on: June 01, 2008 - 11:26:58 PM »
the rotor is just slightly smaller then the factory rotor @ 10.5"
Offline Madmax440
« Reply #8 on: June 02, 2008 - 06:10:56 PM »
They are 4 piston calipers and I didn't want to push the size of the rotors since I am dead set on staying on 15's.
Offline kingtroll
« Reply #9 on: June 02, 2008 - 06:37:05 PM »
They look awesome....  :thumbsup:
1974 Barracuda
