Author Topic: 340 intake opinions..  (Read 1074 times)
Offline 71fish
  • Bless you..
    • Ken's 71fish
« on: June 02, 2008 - 01:41:44 PM »
Is there a concensus on the best 340 intake? My 340 is 9.5:1 ported J heads and a 750 carb. I currently have a single plane offy. I hear the air gap is pretty popular as well as the eddy performer. Shouly I use a single plane or 2 plane.
The torque is nice but with 3:91 hears should I use a single plane? Thanks for the opinions in advance.
71fish
71fish - Nobody better than an E-BODY!!
Offline Rob C
Re: 340 intake opinions..
« Reply #1 on: June 02, 2008 - 06:23:41 PM »
In most cases, nower days, the high rise dual plane is allmost impossible to beat on the street. The single plane intake shold be left alone for racing. The high rise dual plane has more torque down low and gives nothing up on high rpm's to the single plane intakes.
Edel.'s RPM, ethier style, Weiand Stealth, etc......
Low rise dual planes should be left on the shelf for most high performance street rides. The Weiand Action plus is an exception to the rule in the way they (Weiand) advertise it. As a replacement of sorts. The performer can really wake up a 318 and smaller engine well, but is not much better than a OE iron intake on the larger mills. 340 and up.
For a single plane intake, I like the Mopar M-1 with a T-Q on top. Learning the way to tune a T-Q will throw most people a curve and the difficulty will have a different carb on top quick for many. I noticed Steve D. of MoparMuscle mag seems to like them. I remember he tuned on up and made more power than a Holley and a dual plane on a Big Block. Thought that was interesting.
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #2 on: June 03, 2008 - 01:53:08 AM »
I would go with a high rise dual plane like the Edelbrock RPM intake.  It will give you good torque and hp for the street.  I have heard the Weiand Stealth is good, but I have never tried it.
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #3 on: June 03, 2008 - 08:20:59 AM »
thanks for the advice. Will the eddy RPM fit with the shaker? I have an otrg shaker setup and would like to hear if the RPM high rise cause any clearance problems.
Thanks
-71fish
Offline Jacksboys
« Reply #4 on: June 03, 2008 - 10:38:47 AM »
I am not sure about the shaker, but I had to have a low-rise aircleaner on my carb, because I would have hit the hood other wise
Offline vinb
« Reply #5 on: June 03, 2008 - 10:31:35 PM »
Try one of these Weiand dual planes , the #8007 is a spread bore for a T-Q or the #8022 Square bore for a Holley..
Works for me and it should fit with the Shaker. I also use a 3/4" spacer with the T-Q.
I ran a taller intake and a taller spacer on my SuperStocker years ago with the shaker and had no height problem..
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #6 on: June 04, 2008 - 07:40:05 AM »
Awesome! Thanks guys.
71fish
