Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
8 3/4 rear end
« previous
next »
Print
Pages: [
1
Author
Topic: 8 3/4 rear end (Read 1082 times)
kmyles
Sr. Member
8 3/4 rear end
on:
June 02, 2008 - 01:54:23 PM »
What is the best setup to go with when it comes to a sure grip? My rear end right now is open and I would like to change it out to a sure grip but not sure what to go with.
Also what is the difference in a clutch setup and one without clutch setup. My car is an automatic so I am again unsure what this is about?
My rearend case is the standard case that would have come with a 318 engine. I have since upgraded with a 383 and now I want some traction when I hit the road
Any help would be appreciated!!
Thanks
Logged
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
kmyles
Sr. Member
Re: 8 3/4 rear end
Reply #1 on:
June 04, 2008 - 03:44:50 PM »
Logged
_________
Kevin
drewcrane
Sr. Member
Re: 8 3/4 rear end
Reply #2 on:
June 04, 2008 - 04:59:29 PM »
well first you need to figure out if you have an 8 3/4 rear you may have an 8 1/4 , check that first, they might have posi units for those too!
Logged
do i need spell check?
http://www.youtube.com/watch?v=U19M6pY2qIE
http://www.youtube.com/watch?v=pdxh73APkL8
kmyles
Sr. Member
Re: 8 3/4 rear end
Reply #3 on:
June 04, 2008 - 05:06:27 PM »
It's for sure an 8 3/4
Logged
_________
Kevin
Chryco Psycho
Administrator
C-C.com Guru
Re: 8 3/4 rear end
Reply #4 on:
June 14, 2008 - 04:11:58 AM »
the rebuildable clutch type is the best , the Torson . true track is second best but needs to use green axle brgs , the cone type is a throw away , it cannot be rebuilt once it is worn out
Logged
kmyles
Sr. Member
Re: 8 3/4 rear end
Reply #5 on:
June 14, 2008 - 01:43:25 PM »
Thanks Chryco
Logged
_________
Kevin
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
8 3/4 rear end
