Author Topic: wiring help needed Charging issues.  (Read 3181 times)
Offline IMNCARN82
  • LeDZeP
« on: June 02, 2008 - 07:08:01 PM »
So here goes....     I stripped the engine bay,put it all back.   Went with a one wire alternator. Connected the large factory wire (brown/yellow) to the new alt. New voltage regulator in factory position.MSD box is wired to the post on the starter relay.  The factory alternator wire runs into the fuse box or bulkhead connector thingy. Then another brown/yellow wire comes out in another spot and goes to...? The post on the relay? Or one of the two tabs?  Then The + battery terminal goes to the starter,The lead off the terminal goes to the post on the relay. There is a small yellow wire that connects to one of the tabs on the relay. My fans are on the other.   The problem has been no charging. It was charging. Then I found a loose connection. Then it worked again. Then another loose connection! Then it worked again. Then I loose track ...  I'm frustrated. The new alt. is a 75 amp. deal. The guage pegs when any gas is applied.At idle it will drop just a little....when it is working.   Guages are brighter. Turn signals faster brighter.  Do I need the factory voltage regulator?        If someone could just tell me where all the wires are supposed to go mayby I can get it going again.  I have a multi-meter.     :1zhelp:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline 422STROKER
  • Member Since 6/3/06
Re: wiring help needed Charging issues.
« Reply #1 on: June 02, 2008 - 09:00:50 PM »
I don't think You need the VR.
The one wire deal has it's own regulator.  Try running a new bigger wire(at least 10 guage) to the battery with a fuse in line.  That should do you up nice.  I'm not sure what you did with the 2 wires that used to go to the alt before though.
I bought a smaller Amplifier kit and it had a #8 and a 40A inline fuse already installed.  I added this in addition to the factory wiring on mine.
Tom :2thumbs:
Start with a fully charged battery, the alt isn't designed to charge a dead battery.
Tom
Offline 422STROKER
« Reply #2 on: June 02, 2008 - 09:01:58 PM »
What is your voltage at idle at the battery?
Tom :wave:
Tom
Offline IMNCARN82
  • LeDZeP
« Reply #3 on: June 02, 2008 - 09:55:19 PM »
Hey Tom..   The battery shows 10.5      I'll charge it up some. It might start now.  It's so weird. It was completley dead...nothin'   Then I popped the alt. wire off and it wanted to go...?    This is nuts.  What's this about running my own wire. When I did that ...no guage    :dunno:        As it sits...  Not enough juice to start it. But I got guage.  It's so freakn' random   I'm at a total loss here.   I'll toss the charger on it and try it some other time.  damit. :stomp:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline 422STROKER
« Reply #4 on: June 02, 2008 - 09:59:24 PM »
Yeah my Amp guage only reads what is left of the current through it.  I added a voltmeter to keep an eye on the battery.  So I was thinking if you added a new wire it would eliminate any car issues and begin charging.  I think something seems crossed up with your factory stuff.  Or the alternator isn't grounded good?  Do you have the engine to firewall and battery grounds in?
Tom
Tom
Offline IMNCARN82
  • LeDZeP
« Reply #5 on: June 02, 2008 - 10:16:56 PM »
Yeah both grounds.   I'm going out to scratch some paint off the back one :dunno:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline 422STROKER
« Reply #6 on: June 02, 2008 - 10:27:28 PM »
Tom
Offline IMNCARN82
  • LeDZeP
« Reply #7 on: June 02, 2008 - 10:57:45 PM »
Thanks Tom !!  That helps alot!   So if I run that one big wire from the alt. to the battery terminal will I have a factory guage?
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline 422STROKER
« Reply #8 on: June 02, 2008 - 11:32:55 PM »
No. I would add it too what you have now so unless You do a complete bypass of the ammeter.
You can take the 2 wires off the ammeter and connect them or bypass the bulkhead connector by drilling a hole for a continuous piece of wire(MAD upgrade do search).
For now just bypass by adding a wire and see if it charges fine.  When You see it work, You can attack a permanent fix that ill look/function well.
Tom
I had used a plug in Voltmeter in the cigar lighter temporarily to keep an eye on the charging situation. :2cents:
Tom
Offline IMNCARN82
  • LeDZeP
« Reply #9 on: June 02, 2008 - 11:48:31 PM »
O.K.   I'll try it.  Thanks Tom    Gosh it's frustrating for me.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline hemiken
« Reply #10 on: June 03, 2008 - 07:19:24 AM »
I thought i would jump on here for moral support more than anything else, i hate wiring but hope you work it all out with Tommo's help :2thumbs:
« Last Edit: June 03, 2008 - 06:28:36 PM by hemiken »
Offline 422STROKER
« Reply #11 on: June 03, 2008 - 03:57:07 PM »
 :popcorn:
Tom :bigsmile:
Tom
Offline IMNCARN82
  • LeDZeP
« Reply #12 on: June 04, 2008 - 02:18:22 AM »
I'm running again!! :woo:   Thanks Tom!!   And you Hemiken.   Now I need more gas...  I've been driving around causing a rukus.     :bigsmile:   I luv it.    My buddy had to check out the 5 speed. I've only had her up to 85 and she's got lot's more.With 3:91's .This is sweet. :bigsmile:   It's purring like a kitten right now!   :2thumbs:  It's hard to believe this thing is mine!! :crazy:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline hemiken
« Reply #13 on: June 04, 2008 - 07:29:15 AM »
I am so glad that i helped out so much :faint:  I do not want to steal any of Tommo's glory.  You and him did the hard yards together, i was just watching from a distance............. a long distance at that... :smilielol: :2thumbs:
Glad it is fixed, look forward to some video footage when you get the chance :clapping:
Offline IMNCARN82
  • LeDZeP
« Reply #14 on: June 04, 2008 - 09:49:23 AM »
 :smilielol:  Yeah...     a figgn' one wire alternator      :rofl:   :screwy:      I keep getting some video compressed.Then I can't find them.   :dunno:    imac.     Oh well...  I'll figure it out soon. Got alot to catch up on around here.Had my head focused on the car.     It's so nice.   :cheers:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
