Year one Engine wiring harness
Author Topic: Year one Engine wiring harness  (Read 7545 times)
Offline FY1 RT SE
Re: Year one Engine wiring harness
« Reply #15 on: June 20, 2008 - 01:09:31 PM »
not to be a  smart A*S but if you pointed out that they are all different why are you asking the differences unless your speeking of the obvious differences in body or looks?
Dave, the differences are in function, such as idle and carb solenoids, relays etc.  For example '74 as I stated above is a two piece harness, but actually there are two of them.  One for cars built before Oct and one after.  Three different part numbers make up these harnesses.  Also, in taking a quick look at the harnesses you have listed I have to ask again on the 70 "A" body where is the other half of the harness.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #16 on: June 20, 2008 - 04:05:26 PM »
So the cheapest rout t for me if all I need the harness for is oil, temp, horn, washer,  what am I missing ?
I do not need a distributor hook up or alternator; am I missing something. I have independent wiring for that stuff.
So would the 70 340 be the cheapest way to go?
Go Fast & Have Fun...
Offline PlumCrazy
« Reply #17 on: June 23, 2008 - 10:49:24 PM »
Least expensive would be a 340 or 440-6 harness from Year One.  Take it apart and remove all the wires you do not need, then retape it.  Make sure you use the "Moparts" discount.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #18 on: June 24, 2008 - 08:08:33 AM »
you also could just by the engine harness connector at the fire wall and just make your own harness. This would be the cheapest if that is what your looking for.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #19 on: June 24, 2008 - 08:12:15 AM »
Just to clarify We only have the B/E engine,headlamp,rear harnesses, A is referring to A engine not A-body. Also i do not have orginials here to compare to for reference.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline redfastback
    • my shop
« Reply #20 on: June 24, 2008 - 10:32:28 AM »
year one has an exclusive contract with m&h electrical fabricators.  y1 paid for the r&d and tooling so they got exclusive rights.  i have an account with m&h for all gm stuff, but i can't buy mopar harnesses.
bill and rose evans make some nice harnesses for ebodies.
http://evanswiring.tripod.com/
"barracudas are like the pitbulls of the ocean"
