Author Topic: need to replace a couple of front wheel studs  (Read 879 times)
Offline burrpenick
« on: June 02, 2008 - 10:02:28 PM »
'72 Cuda with discs. One was broken off and worked OK with the steel wheels but will not with the alloys, another is just messed up. I didnt look long, but how do they come out?
Thanks, George
GEORGE
currently Moparless
Re: need to replace a couple of front wheel studs
« Reply #1 on: June 02, 2008 - 10:45:07 PM »
BFH
Offline GoodysGotaCuda
« Reply #2 on: June 02, 2008 - 10:56:37 PM »
Remove the rotor from the car, (dust cap, cotter pin, star retainer, nut, bearing, rotor). I'd lay the rotor on some wood face up instead of dead on concrete. Hammer the stud into the rotor hub (use ear protection :D). To install the new one you can get some washers, oil on the threads and a lug nut and tighten it in. Last time i did studs (rear axle) i decided to tap them in from behind. Using a good size punch or even a 6" 1/2" drive extension will do the job. Again let the rotor lay on some sort of wood, it is 'fragile/delicate/brittle' i should say against sharp rapps.
1976 Dodge Warlock
Wheel & Tire Specs:Link
