'72 Cuda, stock ignition w/Blaster coil. Usually works fine, but occasionally it will not make a sound when the key is turned. A light tap on the relay/solinoid usually makes it better. I removed that relay, sanded behind it VERY well, same issue. I suspect its the neutral safety wire. I just have it run directly to ground behind that relay on one of the mounting bolts. I scrapped the tab inside the plastic that plugs on to that relay too but I cannot be sure that it is getting good contact. Am I on the right track? Ideas? Ground the neutral switch somewhere else? Get the plastic tab off and bend the tangs on the plus to make sure it is getting contact? Replace the relay.....it is original I believe.
thanks, George
PS: This is NOT my switch, but it looks just like this one.
