Author Topic: Fresh Oil Change Yesterday  (Read 1266 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« on: June 03, 2008 - 04:10:09 AM »
Took the Cuda out of storage and changed the oil.  This stuff cost $4.29 per quart.   :22yikes:
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline Rare_T_A
    • Freiss Family Mopar Site
Re: Fresh Oil Change Yesterday
« Reply #1 on: June 03, 2008 - 09:58:08 AM »
$4.29 times 6 = you don't want to do it to often.   :money:
'09 Challenger R/T  5.7 HEMI Auto
'70Challenger T/A 340 727
Fargo, N. Dak.
My web Site:  http://freiss.co.nr
My Flikr Page: http://www.flickr.com/photos/102813164@N04/
I was born with nothing and I still have most of it left!
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: June 03, 2008 - 10:35:32 AM »
Yep . . oil is having an effect on everyone!   :banghead:
Offline LAA66
« Reply #3 on: June 04, 2008 - 10:21:46 AM »
 That is pretty expensive indeed.  :faint: As an alternative, at about $2.50 a quart, does anyone have an opinion on running diesel motor oil such a Chevron Delo 400 or Shell Rotella T 15w-40. I heard these still contain the additives most of the automotive oils have eliminated.  :clueless:
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #4 on: June 04, 2008 - 11:24:12 AM »
the folks at Comp Cams recommended I use the Rotella T for cam break-in, but told me a lot of folks just keep it in and swear by it!! :2thumbs:
                                                         Matt B.
Matt
Offline backtobasics
« Reply #5 on: June 04, 2008 - 12:28:18 PM »
The diesel oil will be losing all of the extreme pressure additives soon, to keep compliant.   The additives, were killing the converters, and now most of the diesels are catalytic converter equiped.
Best is to buy several bottle of the break in addtive that Comp Cams sells, and add them to basic oil during the oil changes.
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #6 on: June 04, 2008 - 04:11:10 PM »
That is not too bad, I'm using the $7.00 Royal Purple 10w-40 in mine.   :money:  Good thing it is only once a year.
Offline LAA66
« Reply #7 on: June 04, 2008 - 11:30:33 PM »
Best is to buy several bottle of the break in additive that Comp Cams sells, and add them to basic oil during the oil changes.
 I heard the same thing that the additives will soon to be removed from the Diesel motor oils. i am rebuilding a tractor motor right now and the machinist said to keep an eye out for the change. The engine needed an atomizer and along with the order came an additive that is suppose to help maintain the injectors. Are the the necessary components in Diesel fuel now being removed too. If so, would that be the Sulfur?. Thanks!
Offline IMNCARN82
  • LeDZeP
« Reply #8 on: June 04, 2008 - 11:37:35 PM »
I got Rotella in this new motor right now. Using it for break in. Good stuff. Been using it awhile now.   I may switch to  castrol with an additive after 500 miles  :dunno:   Hmmmm..... :popcorn:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #9 on: June 04, 2008 - 11:45:00 PM »
how about 6qts of Valvoline synthetic for $9.00?
http://www.oreillyauto.com/EW3/GetUpload?id=topRebates11.pdf
Offline hooD
  • detroit iron
« Reply #10 on: June 05, 2008 - 03:26:10 AM »
 :clueless:  You both mentioned 6 quarts.  The specs say engine capacity is 4 quarts.  Add 1 quart when changing the filter.  That's 5 total.  Do you all have a larger oil pan?
I have always used only 5 quarts when doing an oil change and filter.
-Larry
1973 'CUDA 340
original owner
37,117 miles
« Reply #11 on: June 05, 2008 - 07:03:27 AM »
just happened to be what the deal is for..... 5qts does my 340...... 4.6L in my GT takes 6
