Author Topic: What hooks to the brake pedal??  (Read 2245 times)
Offline 1970-cuda340
« on: June 03, 2008 - 07:04:08 PM »
When I bought my cuda it was missing the master cylinder. After I pulled the dash I don't see any linkages that goes to the M.C. Anybody got a pic of what I need. Once I find out what's missing I will post in the wanted section for the parts.
Thanks
Robert
Here's a pic of what I have.
Offline GoodysGotaCuda
Re: What hooks to the brake pedal??
« Reply #1 on: June 03, 2008 - 07:13:19 PM »
You running manual or power brakes?
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #2 on: June 03, 2008 - 07:13:34 PM »
Power or standard brakes? Disc or drum?
« Reply #3 on: June 03, 2008 - 07:22:59 PM »
Tough to tell from that pic.    :dunno:
Offline FY1Cuda
« Reply #4 on: June 03, 2008 - 08:03:48 PM »
If you have power brakes, it looks like you're missing the lever and push-rod assembly.  These pieces bolt in between those two big braces under the dash and are extremely awkward to get in or out (unless I don't know how to do it the right way).  My only experience has been with power brakes so I can't say what you need for standard brakes.  I wonder if a lot of these pieces are shared by other Mopars--Chryco could tell you.
« Last Edit: June 03, 2008 - 08:07:13 PM by FY1Cuda »
« Reply #5 on: June 03, 2008 - 08:06:19 PM »
I may have them awkward pices from under the dash if you cant find them
« Reply #6 on: June 03, 2008 - 09:29:09 PM »
Sorry guys. it's a manual setup w/ front disc brakes. All that's there is a pedal with a hole and a small bolt pattern for the master cylinder.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #7 on: June 03, 2008 - 09:30:31 PM »
You just need to the pushrod then.
Tom :2thumbs:
Tom
« Reply #8 on: June 03, 2008 - 09:32:07 PM »
Is that a hard to find item?
« Reply #9 on: June 03, 2008 - 09:34:38 PM »
Also the brake lines are a mess. Is there a proportional valve somewhere. I cannot find one.
Offline 422STROKER
« Reply #10 on: June 03, 2008 - 09:47:32 PM »
MP sells new adjustable ones or You can hit the Pick-A-Part.  Yes ther should be some sort of distribution block below the M/C area.  Some of the vendors have the prop valve and lines too.  Fine Lines etc. :2thumbs:
Tom
Tom
« Reply #11 on: June 03, 2008 - 10:03:38 PM »
Cool. Thanks!!  :2thumbs:
« Reply #12 on: June 14, 2008 - 04:09:26 AM »
I often use a Tee to the front brake lines & an adjustable proportioning valve to the rear brakes , the only down side is the lack of brake warning light , but the adjustment can be fine tuned
Offline FY1 RT SE
« Reply #13 on: June 19, 2008 - 03:35:07 AM »
That combo was not available from the factory in '70.
