Author Topic: battery cut off switch  (Read 1313 times)
Offline boomer
« on: June 03, 2008 - 08:32:03 PM »
i mounted a switched battery cut off on fender well. i run positive battery cable from battery in trunk to one side, a heavy red wire from starter to the other.on the starter wire side i added a msd box wire and a wire from solenoid to the starter side. using the switch i could turn off all power.there was power on both sides when the switch was turned off, did i get a bad switch or something im over looking. You were alot of help before, hopefully you understand my question, thanks
Offline 422STROKER
  • Member Since 6/3/06
Re: battery cut off switch
« Reply #1 on: June 03, 2008 - 09:50:34 PM »
Do you have a picture of the switch, also how are you checking for power on both sides?
Tom
Tom
« Reply #2 on: June 03, 2008 - 11:33:25 PM »
Was the car running when you tried?  Alternator amp wire would be juicing everything up
Offline Aussie Challenger
« Reply #3 on: June 05, 2008 - 07:32:52 AM »
  I think a pic or more detailed explaination is needed......    :popcorn:
Offline 422STROKER
« Reply #4 on: June 06, 2008 - 05:20:52 PM »
Gone....... :violin: :popcorn:
Tom :banghead:
Tom
