Author Topic: Clutch Start Switch  (Read 7571 times)
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: Clutch Start Switch
« Reply #15 on: June 05, 2008 - 10:39:44 PM »
B and E are different. but they have them either way
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline matt63
« Reply #16 on: June 05, 2008 - 11:35:03 PM »
the only one that I know that has correct switches is Brewers. they are about 400.00
I think they are $250 - check the site
Matt in Edmonton
'68 Valiant
Offline LAA66
« Reply #17 on: June 05, 2008 - 11:43:49 PM »
I'll go ahead and ground the relay for now to keep things moving forward and keep my eyes open for a safety switch in the in the future.  Are originals safety switches hard to come by?
 Run a female spade type connector at the relay and wire it too the major ground on the front radiator support. Connect it to the proper post and the ground will be complete.
Turning the key to start while in gear will send the vehical in motion so be careful.  When you find a clutch switch simply unplug it and connect the clutch switch "green wire" to the same post.  :2cents:
  I keep the clutch switch bypass in place, and ready, as the factory switch is known to fail. There is an easy fix for them though. :naughty:
Offline troutstreamnm
« Reply #18 on: June 06, 2008 - 07:59:24 PM »
WOW, I had no idea these were so expensive  :faint:  I always engage the clutch before starting a vehicle anyway to be safe. but for that kind of money, I'll have to wait for a switch to fall from the sky!  Seems like it would be pretty easy to use another type of switch to ground the circuit.  Anyone solve this with cheap parts?
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #19 on: June 06, 2008 - 08:09:31 PM »
Maybe a door pin switch or a brake light switch?  :dunno:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
« Reply #20 on: June 14, 2008 - 03:31:30 AM »
I used a brake lite switch to get by an inspection here , , it doesn`t work right in that the clutch only needs to be depressed 1" or so , but the car will not start without moving the clutch at least
