Author Topic: Shifter Bezel Blues  (Read 770 times)
Offline CUDA JAS
  • vroooooom!
Shifter Bezel Blues
« on: June 04, 2008 - 10:13:08 AM »
Any suggestion on fixing my slap stik shifter bezel?
The blue light cover on the inside of the bezel is busted.  It is still in there and looks to be intact, just busted around the base.
Any sugestion on how to pull the bezel apart, fix it and put it all back together?
Thanks,
Jas
74 'cuda 360/727
Just call me a gearhead!
Re: Shifter Bezel Blues
« Reply #1 on: June 04, 2008 - 10:23:00 AM »
You waiting on a sm blk pump from me?  I am getting it out right now.  I dont think I have the part your needing for your slap stick tho. Should be easy to find and replace :2thumbs:
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: June 04, 2008 - 10:59:45 AM »
Hey Al if you mean a manual sterring shaft, yep..thanks for the update.  I will also send out the drip rails to you this week!
Yeah, I think I could find the part, but I am just about taped out on this project, and this is another one of those little unanticipated costs, so I was hoping to fix it and just make do with it for now.
Thanks,
Jas
74 'cuda 360/727
Offline MrMopar440
« Reply #3 on: June 05, 2008 - 02:30:22 AM »
I ended up supergluing my light cover to the base. It doesn't get much contact or movement so only a little contact area seemed to be necessary. I popped the housing off the rivets (carefully) and then pressed the housiing back on. I used a little bit of epoxy to re-secure. No problems so far.
