Author Topic: Sprecks 1971 Challenger Convert do over  (Read 10302 times)
Offline sprecks
« on: June 04, 2008 - 08:06:52 PM »
I decided to re-do my Convertible again. This is like I should have done it when I first did it 12 years ago. The car started life as a 318 automatic with A/C. It now has a 426 Hemi with an automatic, Dana rear, R/T hood and rear spoiler. After this rebuild it will still have the same drive train. I am adding a shaker hood, all new floor pans, new fenders and new rear frame rails. I'm doing all of the work myself with help from a welding buddy.
Currently the frame rails and floor pans are installed and I'm getting ready to pull the engine this weekend. I hope to have it on the rotisserie this weekend as well. Here are some pictures of the work so far.
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
Offline sprecks
Re: Sprecks 1971 Challenger Convert do over
« Reply #1 on: June 04, 2008 - 08:08:13 PM »
A few more to get up to date.
you can call me Jay
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: June 04, 2008 - 09:01:38 PM »
Looks good sprecks, keep up the good work.
Tom :2thumbs:
Tom
Offline ChallengerGary
    • Challenger Gary
« Reply #3 on: June 04, 2008 - 09:30:00 PM »
Loks like a great project.   :2cents: Make sure you brace it before you put it on the rotis - you'll be sorry if you don't.
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline sprecks
« Reply #4 on: June 04, 2008 - 09:34:03 PM »
Thanks for looking out for me with the brace suggestion. I have the braces made up and ready to go.
you can call me Jay
Offline hezzel
  • Matching numbers 383 Magnum ,727 at and 3:23 rear
« Reply #5 on: June 05, 2008 - 01:59:46 PM »
Looks like a nice project   :ylsuper: Good luck with it :2thumbs:
1971 Dodge Challenger R/T
2019 Toyota Rav4 Hybrid
Offline ksierens
    • 70 Challenger Resurrection
« Reply #6 on: June 05, 2008 - 02:15:29 PM »
Looks like a great project, keep those pictures coming!  :bananasmi
Kurt - SE Michigan
Offline resqguy
« Reply #7 on: June 05, 2008 - 03:18:57 PM »
Quote
Not to hijack, but does anyone have a template or specs for making the braces?
Offline sprecks
« Reply #8 on: June 05, 2008 - 08:24:11 PM »
Basically with the doors and hinges off the car and striker pin/bolt removed, bolt a piece of angle iron where the upper hinge was. Next bolt another piece of angle iron or flat plate using striker pin/bolt hole. Now cut a piece of pipe or square tubing to fit between the two pieces of angle iron and weld in place. After it is welded it can be removed and reinstalled when you need it.  Hope this helps.
you can call me Jay
Offline ShelbyDogg
« Reply #9 on: June 05, 2008 - 10:42:17 PM »
I made mine from angle from an old bed frame. It is tacked on the front but still bolted with one bolt. On the rear, I welded it to a plate that is bolted to two of the holes where the top bolts on. My doors can still open and close to check the gaps when welding the rear quarters and aligning front fenders.
Nice job on the floors. I'll be doing the same thing after I fix my HOLE-Y cowl.
« Last Edit: September 18, 2008 - 12:36:00 AM by shelbydogg »
Offline sprecks
« Reply #10 on: June 13, 2008 - 07:08:41 PM »
Shelbydog - I like the way you did your bracing. I'm planning on leaving the doors off while it is on the roitisserie so I'll use the braces in the picture. I'll sure keep your's in mind for future projects. Thanks.
I couldn't find the old braces from the last time I did this so I made some new ones. Check out where it is bolted to the striker. Recoginize that piece? You guessed it. Solid motor mounts. They worked great. Nothing like a little improvising when you don't have the correct materials on hand. This baby will be rolled over on its side in the morning. I'll post more pictures tomorrow.
« Last Edit: June 13, 2008 - 08:22:52 PM by sprecks »
you can call me Jay
Offline ShelbyDogg
« Reply #11 on: June 13, 2008 - 09:08:17 PM »
That's a nice brace!  I have a spare set of those too. The hole is already big enough for the striker bolt too.
Offline BIGSHCLUNK
« Reply #12 on: June 14, 2008 - 12:18:38 AM »
I have a pair of nice gas tank braces if you have a need. Theyre leftovers fromwhen I did my trunk last winter...
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline sprecks
Sprecks 1971 Challenger Convert do over updated 10/10/08
« Reply #13 on: June 14, 2008 - 07:52:04 AM »
Thanks for the offer. I already have new ones welded in.
« Last Edit: October 10, 2008 - 08:20:17 PM by sprecks »
you can call me Jay
Offline ShelbyDogg
« Reply #14 on: June 14, 2008 - 09:50:05 AM »
One observation sprecks,  You may want to cover your dash and windshield and any glass left in the quarters when doing any welding or grinding. I had a good windshield in my old R/T that is now covered in welding and grinding spatter. Melted right into the windshield plastic coating.  Another expense that I didn't need. A welding blanket was less than $20 at Harbor Freight and I now use it to cover anything in the area of sparks.   Check your dash guages for anything already stuck on the faces.
