Author Topic: Sprecks 1971 Challenger Convert do over  (Read 10305 times)
Offline sprecks
Re: Sprecks 1971 Challenger Convert do over
« Reply #45 on: November 16, 2008 - 07:17:42 PM »
Very nice Jay!
Thanks Rob and everyone else too.
Rob, How about an update on the pace car. Have you been working on it?
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
Offline ShelbyDogg
« Reply #46 on: November 16, 2008 - 10:30:28 PM »
The daylight savings change  and cold weather really screwed up my  car hours. I've worked on it a little since my last update but haven't had time to post.   I tried to look up some Body Shop courses at our community colleges, but they don't offer anything here in St. Louis.
Offline sprecks
« Reply #47 on: March 01, 2009 - 07:03:39 PM »
Wow, I haven't posted any updates since November. I finally got back after it some more this afternoon. I've been tinkering all winter but no real milestones. Today I got all but a little trim work done insulating the interior with B-Quiet mat. It went pretty good. Here's some pics.
I made a trunk divder out of a hardtop one and then covered it with the B-Quiet material.
you can call me Jay
Offline mrcuda
« Reply #48 on: March 01, 2009 - 07:12:46 PM »
I was just getting ready to post about what to paint body color, when I saw your post. Is the inside of the trunk  also body color? Do you leave inside the wheelwell body color?  What color is that? Thanks.
Offline sprecks
« Reply #49 on: March 01, 2009 - 07:19:38 PM »
The inside of the trunk is body color on mopars. The inside of the wheelwells have been painted body color. I will black them out later because I think they look better that way. The paint code is GY3 Citron Yella for Dodge, Plymouth called it Curious Yellow.
you can call me Jay
Offline mrcuda
« Reply #50 on: March 01, 2009 - 07:35:53 PM »
Friend just sprayed some Top Banana in the engine compartment so I could see what it will look like. After taking off all that undercoating and getting it down to metal I don't know if I want tpo undercoat it again.
Offline sprecks
« Reply #51 on: March 17, 2009 - 07:53:18 PM »
Had a minor set back today. I thought it would be a good time to check out the bearings in the engine before I put it back in the car. Pulled number 8 bearing and found some scratches so I kept pulling more. They all looked about the same. I ended up completely diassembling the engine. I took the oil pump apart and it's pretty obvious that something went through the pump. So I jumped in the truck with the parts and headed to Chenoweth's Machine Shop. Since the crank was 0.020 under already I bit the bullit and bought a new Eagle piece. Dale is going to rebalance the rotating assembly and hopefully I'll have it back together in a couple of weeks. Good thing I checked it out when I did. This is money I didn't plan on spending but it eventually would have cost more if I had just put it back in the car.
« Last Edit: March 17, 2009 - 08:39:11 PM by sprecks »
you can call me Jay
wagesofsin
« Reply #52 on: March 17, 2009 - 09:24:54 PM »
looking fine nonetheless.
keep up the good work.  :2thumbs:
Offline sprecks
« Reply #53 on: June 01, 2009 - 07:51:35 PM »
Haven't given any updates in a while and figured I better. I got all of the engine parts back from Chenoweth Speed Shop last week so I started assembly this weekend. I pretty much got the short block put together with only a few minor set backs. I installed the crank and rotated it and the crank throws were rubbing the block under #2 main cap. So I had to take the crank back out and give the block some relief with the die grinder. After another block bath and cleanup to remove the grinding dust, I checked my rod bolt clearance to the lower cylinder wall and everything was cool there. Then installed the oil pickup tube and the #1 rod locked everything up as it tried to pass the tube. After a little percussion adjustment I now have clearance there as well. Next I layed the windage tray on and figured I would have to make some "adjustments" on it as well....I did. Here's a pictures of my new 472" baby along with my "adjusted" windage tray.
« Last Edit: June 01, 2009 - 08:04:48 PM by sprecks »
you can call me Jay
wagesofsin
« Reply #54 on: June 01, 2009 - 08:06:57 PM »
looking good!!!
Offline sprecks
« Reply #55 on: June 10, 2009 - 07:54:47 PM »
Hit a major milestone tonight. After I got home I called upon a couple of friends of mine to give me a hand setting the engine and tranny into the car. Here's a few pics. I couldn't get enough down angle so I needed to put a little counter weight on the tail shaft. Yeh... that's me being the counterweight....lol. It's in there and all down hill from here. Hopefully I'll have it running shortly.
you can call me Jay
wagesofsin
« Reply #56 on: June 10, 2009 - 08:25:39 PM »
easy tiger, one false step and....  :smilielol:
congrats on setting the mill and transmixer.
looks great, cant wait to see the vid of it running.   :bigsmile:
Offline usraptr
« Reply #57 on: June 10, 2009 - 11:00:51 PM »
 :2thumbs: Looking good!!  I can't wait until I get my engine installed.  Congratulations!!
(Edited 8-1-17)
Offline ShelbyDogg
« Reply #58 on: June 11, 2009 - 12:27:35 AM »
Nice Jay!
That car looks sooooo nice.
Offline mrcuda
« Reply #59 on: June 18, 2009 - 02:36:39 AM »
Looks geat. Keep up the god work. :2thumbs:
