Author Topic: OIL RATING FOR FLAT TAPPET CAM SHAFTS  (Read 1226 times)
Offline 0tter45
« on: June 04, 2008 - 09:05:39 PM »
Does anyone know the oil rating required to run flat tappet camshafts.  I think it is CI4 that has the appropriate amount of zinc in the oil for cams.
Thanks
Otter
Offline matt63
Re: OIL RATING FOR FLAT TAPPET CAM SHAFTS
« Reply #1 on: June 04, 2008 - 10:35:36 PM »
This is a widely discussed topic in many car forums.  I don't recall any deep technical discussions in this forum.  I can't remember what ratings have sufficient zinc and phosphorous but you need to look for 1200 ppm+ of each according to some of the experts.  Some folks recommend adding wear or break-in additives to increase the levels of these components.  The Zn and P are also referred to as ZDDP.  Some of the boutique synthetic and dino oils have them as do some of the motorcycle oils.  I run a roller cam so it is not an issue.
Matt in Edmonton
'68 Valiant
Offline GoodysGotaCuda
« Reply #2 on: June 04, 2008 - 10:43:25 PM »
Mobil 1 15w-50 is 1200ppm, thats what i run
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 73EStroker
« Reply #3 on: June 05, 2008 - 09:21:09 PM »
I used Diesel 15W-40 as this oil still has Phosphorous and zinc in it and no detergent. I believe the rating was SJ on the can that you should look for. I also ran the GM EOS to break my solid flat tappet cam with no problems at all. Will keep using the diesel oil c/w the EOS as the car will only be run in the warmer months. I have enough EOS for 10 oil changes.
Barry (Salmon Arm)
Offline 0tter45
« Reply #4 on: June 05, 2008 - 10:02:01 PM »
Iam going to use castrol 15w40 CI-4 RATED IN MY NEW STROKER.   I have huges breakin oil additive for my flat tappet cam and iam going with the Gm Eos on the oil changes.  The eos is like 8 canadian a bottle.
Otter
