Author Topic: number of specific challengers...  (Read 9398 times)
Offline 2TAGS
Re: number of specific challengers...
« Reply #30 on: June 18, 2008 - 02:11:05 PM »
It does not say N/A though either.  ;)
Since it was only availabe with the A66 package which was covered seperately, they apparently left that space blank?
I agree.  The 340 was intended to be in the A66 cars only so leaving it blank made the most sense.
Could you verify the production #'s you listed earlier?  My 6th edition white book shows more.  Also, are you aware of any non-A66 1970 340 Challengers?  Through your registry or buildsheets waiting for their owners?  Thanks!
1971 'Cuda 340
Alaskan_TA
« Reply #31 on: June 18, 2008 - 10:15:57 PM »
So....would you say ALL 340s were A66 cars?
For 1970 Challengers either A66 or A53 for 340 cars.
Alaskan_TA
« Reply #32 on: June 18, 2008 - 10:16:46 PM »
The numbers I quoted were from the 4th edition.
Offline LAA66
« Reply #33 on: June 18, 2008 - 10:22:11 PM »
Actually, the Yellow Jacket was the design exercise for the T/A.
It was just too expensive to produce in numbers.
The A66 vs. A53 code on the two pilot cars does bring a question to mind as far as the sales percentages go though.....
Were they counted as A66? A53? Or both maybe?  :clueless:
 So the A53 code appeared on the two pilot cars only? The rest were A66?
Alaskan_TA
« Reply #34 on: June 18, 2008 - 10:35:31 PM »
340 four barrel Challengers were A66 package cars.
340 sixpak Challengers were A53 package cars. (T/As)
The two T/A pilot cars started life as A66 cars, but were modified and sold with options normally found (later on) on the A53 package cars.
Offline LAA66
« Reply #35 on: June 19, 2008 - 12:12:30 AM »
 If I understand you correctly the A53 was the code for the T/A and that number is pretty much know. All other 340's set in a Challenger, in the 1970 model year were A66's. No two barrels, flat hood, dog dish rim, plain Jane's had a 340? Thanks!
