Author Topic: Pistol grip w/Competion Plus shifter  (Read 3042 times)
Tower Rat 95B
« on: June 05, 2008 - 08:19:27 PM »
 First  OEM for 1970 was Hurst Competion Plus ,right or wrong??????     Do they shift any good?  Mine is new but shifts terrible 1st and reverse are really really close and going to 3rd is not as smooth as I would expect  4th seems ok , but all things considered this shifter is either junk or needs some adjustments.......   So how is yours, smooth or not smooth?
Re: Pistol grip w/Competion Plus shifter
« Reply #1 on: June 05, 2008 - 08:22:07 PM »
I think you better re adjust your levers. My 70 original goes in everything just the way it should. When you get it right it really just goes right to where it needs to. Everything is smooth here. But I do know if you have a side cover off about 1/8th it will make shifting troublesome :bigsmile:
Offline hemiken
« Reply #2 on: June 05, 2008 - 09:14:40 PM »
 :iagree: :swaying:
Tower Rat 95B
« Reply #3 on: June 05, 2008 - 10:51:28 PM »
 Ok thats a positive post, there is hope for aa smooth shift .......  I do have an old 70's Chiltons manual made I can find the technic to shifter adjusting.........
                                          Thanks
« Reply #4 on: June 06, 2008 - 08:05:55 AM »
You use  what I think is a 1/4 inch allen wrench in a slot under the shifter. This aligns the levers all in a neutral row. With the levers secure, you adjust the rods so that the linkage tabs fit with ease on the transmission. The tabs need to be for your car and not for like a 68 road runner. It sounds like you have 1 rod out of adjustment, making the cross over from second to 3rd hard. Should be an easy fix.
Tower Rat 95B
« Reply #5 on: June 15, 2008 - 08:40:58 AM »
 Thanks Moparal those are good instructions also gave me a flashback to back in the day cause I forgot all about that method  :bigsmile:.....
« Reply #6 on: June 20, 2008 - 07:50:16 AM »
Yer welcome. I need to do it again myself since I just did a new clutch on my car. Chryco made a comment that mine was a bit off again and he wanted to adjust it for me. I wouldnt let him. It is hard to keep that man from tinkering on your stuff when he visits. I knew mine was off some, but not bothersome. As it was, he still ended up playing with my car some.
« Reply #7 on: June 20, 2008 - 01:06:41 PM »
Who me ???
« Reply #8 on: June 20, 2008 - 01:11:47 PM »
Who me ???
 :lol:  Yeah you , mr innocent. You have to make evrything just perfect. :ylsuper:  Oh and thanks again for soldering that wire on my wiper motor. I was to blind to see it.
I am in my truck on wireless going down the road now heading to Michigan....you there?
« Reply #9 on: June 20, 2008 - 01:15:58 PM »
no back in canaduh freezing , we have had highs in the 65-70* range & lows in the 40s  :faint:
 I appolagize for making your car work better  :roflsmiley:
« Last Edit: June 20, 2008 - 01:18:21 PM by Chryco Psycho »
« Reply #10 on: June 20, 2008 - 01:17:48 PM »
well if you came to 4c's again for his block, I am going by the area :2thumbs:
« Reply #11 on: June 20, 2008 - 01:18:48 PM »
not sure when the block will even get machined at this point
Tower Rat 95B
« Reply #12 on: June 29, 2008 - 08:59:19 AM »
 You the man, was an easy fix  :2thumbs:, the middle rod was way out atleast 1/4 inch now it shifts like a hot knife thru butter :bigsmile: :wow: :burnout: :bananasmi,,,,,,,,,,,, very happy thanks :2thumbs:
« Reply #13 on: June 29, 2008 - 01:25:20 PM »
 :2thumbs:
the Hurst Comp + generally works very well
sleepychallenger
« Reply #14 on: August 22, 2008 - 06:53:25 AM »
does it matter which one you get?
