Author Topic: Swirl Mark Help Request  (Read 917 times)
Offline matt63
« on: June 06, 2008 - 12:35:32 PM »
After spending many hours wet sanding and polishing the paint on my dark blue Cuda it looks pretty good.  However, in bright sunlight you can still see swirling.  It kind of looks like grease swirled on the paint and not the swirling scratches. It bugs the heck out of me.  Does anybody have ideas as to what to try?  Perhaps I should try another application of the swirl remover or...?  I am using a rotary buffer.  Perhaps the speed is too low??
Matt in Edmonton
'68 Valiant
Offline RusTy/SE
  • Just havin' fun
Re: Swirl Mark Help Request
« Reply #1 on: June 06, 2008 - 01:47:11 PM »
April got some amazing results using corn starch a few years ago. :thumbsup:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline Desertfish
« Reply #2 on: June 06, 2008 - 05:21:05 PM »
You can try Imperial hand glaze or 3m filling glaze.
Offline wedgehead5000
« Reply #3 on: June 06, 2008 - 05:32:36 PM »
We at my shop use 3m#05954 rubbing compound with a #5723 foam pad to buff with  it will not leave any swirl marks if done right. We then com back with Meguiars #83 polish with a #5725 foam pad. This system works fantastic on dark cars. We just finished a 32 Hiboy that was black with no swirl marks. We do not even use swirl mark remover as this just fills them and they will come back if not taken out to begin with.
Offline matt63
« Reply #4 on: June 06, 2008 - 07:04:31 PM »
This is interesting as the rubbing compounds seems to be a heavy cut polish probably similar to what I used.  However, the Meguiars #83 is a cleaner/polisher which I'm guessing is a little more aggressive than the swirl removed.  Perhaps that is what I need to try.  I'll give it a shot.
Thanks to all for the suggestions - I'm still scratching my head on the corn starch  :clueless:
Matt in Edmonton
'68 Valiant
Offline matt63
« Reply #5 on: June 09, 2008 - 07:58:02 PM »
I had some Meguiars Fine Cut Cleaner so I spent the whole Saturday morning polishing the sides and roof.  I think it looks better but we've had to bright sunlight and none is expected this week so I'll have to wait and see if this did the trick.
Matt in Edmonton
'68 Valiant
Offline cudadave72
  • you motorboatin sob!!!
« Reply #6 on: June 09, 2008 - 09:45:40 PM »
If that doesnt work use 3M swirl remover/polish with a 3M black foam polishing pad. Its the last step before wax that I use on every dark colored car. A coat of Meguires Gold class wax should seal it up nicely! :2thumbs:
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
