Author Topic: 70-74 E-BODY POWER WINDOW CONVERSION KIT?  (Read 21524 times)
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« on: June 06, 2008 - 07:33:44 PM »
 Has anyone used one of these kits?     :dunno:        http://www.paddockparts.com/Paddock/productr.asp?pf%5Fid=CR487074K&gift=False&HSLB=False&mscssid=0A9E2929197D34B168CBBDF1A7E19544
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline Katfish
  • 70 Challenger
Re: 70-74 E-BODY POWER WINDOW CONVERSION KIT?
« Reply #1 on: June 06, 2008 - 07:38:36 PM »
If this is the A1 Electric Life kit, steer clear.  I installed 1 side, was so disappointed I sent it back.  You'll get some people claiming it works to some degree, but if you really press you'll hear the same story.
"Drops like a rock and struggles to raise"
Offline CHUCKS71
« Reply #2 on: June 06, 2008 - 07:40:58 PM »
Thanks for the info!
Offline Katfish
  • 70 Challenger
« Reply #3 on: June 06, 2008 - 07:56:42 PM »
I'm waiting to hear some feedback on the XV kit.  Might work better, but it's very pricey.
Offline willhaven
« Reply #4 on: June 06, 2008 - 11:09:07 PM »
The XV kit should be in my car. Whenever that gets finished...  :bricks1:
If I get the car soon and remember this thread, I'll let you know how they work.
I do recall John stating that there is a design flaw in many of the aftermarket (one size fits all) type of power window kits and that theirs was designed to fix the problem. I guess we'll see.
Offline MoparCar
« Reply #5 on: June 06, 2008 - 11:10:45 PM »
I believe this is the supplier for the XV windows. Although they don't list e-body on their website they did in a recent steet rodding ad.
http://nu-relics.net/
Wes
Offline gkring
« Reply #6 on: June 07, 2008 - 10:24:16 PM »
Wes
Thanks, I was looking for that link when I saw this thread, couldn't remember their name. Click on pricing and they list E bodies as well!
Cuda's and Challengers
2 windows -$480.00
4 windows - $880.00
Kits include regulators/motors, GM Chrome or Black Illuminated switches/wire harness and conduit
Greg
1970 Barracuda driver
Offline bb71challenger
« Reply #7 on: June 08, 2008 - 01:26:29 AM »
Yeah, steer clear of the electric life 2 window kit. I put it in my Challenger right before it went in for paint and was discouraged to say the least. The fast rate of descent would not be so bad but the struggle to lift the window is just rediculous. I am going to either live with the piece of sh....aving cream, go back to manual regulators or get the XV kit. If I get the XV kit I will try to get it without the switches and buy the factory style Chrysler switches to set it off right.
*Brett*
Offline CHUCKS71
« Reply #8 on: June 08, 2008 - 07:18:11 AM »
Do the factory switches cover the hole for the window crank?
Offline larry4406
« Reply #9 on: June 08, 2008 - 09:20:46 AM »
The factory switches mount at the same location as the window crank hole.  However, you have to cut the panel and make the opening square/rectangular to match the switch.  Look at the back side of the interior panel and you will see the outline (I have not done this, but I do have a set of factory power window switches and the size seems to match)
« Reply #10 on: June 08, 2008 - 09:32:11 AM »
Since I was convinced the Electric Life kit would work and since I am going to put a 3 way component set in my car I actually mounted the BMW style rocker switches forward on the arm rest ledge of the door panel. I have to change my interior to white from black so its not a big deal but it sure sucks spending good money on something for a car only to find out its junk.
*Brett*
Offline MoparCar
« Reply #11 on: June 08, 2008 - 11:26:01 AM »
Also, take a look in a few good Street Rodder/Builder (32 coupes, etc.) type magazines. I'm not into the whole old street rod type of cars that much, but they sure inspire me for ideas. There are a lot of great looking billet switches available also for window kits, etc.
Wes
Offline EFI-Cuda
  • 1974 Cuda 408
« Reply #12 on: June 13, 2008 - 12:08:06 AM »
After reading this post, I figured that I'd add my 2 cents.   I have the Electric Life power window kit on my Cuda, and it is true that the windows go down faster than they come up.   When running my factory Cuda's alternator, there was insufficient "juice" to raise the window up faster while the engine was at idle.   If you gave the engine a little more rpm's by pressing on the gas pedal, you will notice that the window goes up much quicker.
Anyway, as time went on, I decided to swich to the Magnum's engine accessories because I wanted to run a serpentine belt and the higher amp alternator.   And, this change fixed the slow window raising problem.   I think that the Magnum's alternator puts out something like 130amps compared to the 65amps on our factory alternators.   And, the Magnum's Denso alternator puts out excellent "juice" at idle.   (No more headlights dimming while I sit at traffic lights)
Anyway, my point is more power = faster window raising.   And, less power = slow window raising.
Again, just my 2 cents.
Cuda 408, Ford EFI, Magnum heads, Vortech V-2 Si-Trim, A-518 transmission and 3.23 gears.
Offline Aussie Challenger
« Reply #13 on: June 13, 2008 - 05:13:23 AM »
  I haven't seen any of these winder kits, however the micro switches on most windows won't carry large amounts of current for too long. Running a relay and wires direct to the battery will increase available current for the winder motor.    :2thumbs:
  Yes a decent ampage alternator will definetly help also.   :bigsmile:
  The kits I have fitted here in Australia were a little on the frail side.   :puke:
Offline Pistol Gripper
« Reply #14 on: June 13, 2008 - 07:09:18 AM »
I like this idea, I'm sure someone makes them for Mopars.
http://www.thehoffmangroup.com/autoloc/product.lasso?prodinc=electricwindowcrank
P.G.
O ne
B ig
A $$
M istake
A merica
