Author Topic: Never ending story  (Read 904 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Never ending story
« on: June 07, 2008 - 02:25:02 PM »
After rebuilding the 340 some months ago I never got the right side headers to not leak towards the head. Cheap ****headers but I tried everything
including coppargaskets and even double standard ones. I mounted the original exhaustmanifolds and I got the exact same leak  :swear:
The reason for rebuilding the engine was that one head was "bended" due to overheating so I bought a pair of Indy rebuilded 318 heads, complete
with bigger valves. Now I start to think that my leakproblem sits in the head and not on the manifold as I first thought. Any thought about this?  :feedback:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline matt63
Re: Never ending story
« Reply #1 on: June 07, 2008 - 02:46:09 PM »
I would check to make sure the headers are not hitting something that would stop them from pulling tight against the head (like a scattershield).  Other than that, if the heads are reasonably flat and the header flange is not warped it should seal.
Matt in Edmonton
'68 Valiant
« Reply #2 on: June 07, 2008 - 03:36:45 PM »
Thats why I mounted the original exhaust manifolds, they are flat with a big sealing surface but still I have a major leak. I start to think
it's a crack in the head?  :dunno:
Offline matt63
« Reply #3 on: June 07, 2008 - 09:03:26 PM »
What are the symptoms of this leak?
Matt in Edmonton
'68 Valiant
« Reply #4 on: June 07, 2008 - 10:59:07 PM »
It's like you didn't tighten the bolts at cylinder eights exhaustport, you hear it and feel it if you put your hand between firewall and exhaust
manifold.
« Reply #5 on: June 07, 2008 - 11:06:12 PM »
What year heads do you have? some had small holes under the ports for emissions and need to be plugged as i recall
« Reply #6 on: June 08, 2008 - 03:26:23 AM »
If I look in the book they should equal heads for a 72-73 318. My engineshop didn't tell me about plugging anything and the other side is OK looking the same.
« Reply #7 on: June 08, 2008 - 09:20:02 AM »
See those little holes under the exhaust ports? Are they holes or where the manifold holes were covering. But those little spots are where exhaust emmision holes are . See if yours are solid or if you have an actual hole there leaking.
« Reply #8 on: June 08, 2008 - 03:56:12 PM »
Thanks, will check this out and come back.  :thumbsup:
