Author Topic: 440 Source Roller Rockers (Sale Pending)  (Read 1077 times)
nivvy
« on: June 07, 2008 - 05:03:28 PM »
440 Source 1.7 Ratio Roller Rocker "Full Rollers"
Less than 100 miles on them since installed.. my k motion springs are too big for these and my spring pressure is also to high for the rockers...
Was $260 new I believe and you cant get 1.7's anymore...I am going to clearence them for spring clearance but I have large diamter springs so im sure yours wont be a problem also...
Comes with 1 extra shaft and spacers.. hold downs not included... but can be had for an additional $70 and they are Mopars and $100 new..
Rockers / Spacers & extra hardened shaft and extra adj. screws and nuts    $170
Hold Downs w/bolts        $70
Shipping        $15
If your lobe lift is lets say .350 all you do is multiply by 1.7  (.350 * 1.7) would give you .595 lift at the valve...
 :2thumbs:
« Last Edit: June 17, 2008 - 08:55:11 PM by StRoKer »
nivvy
Re: 440 Source Roller Rockers
« Reply #1 on: June 09, 2008 - 04:06:45 PM »
$220 to your door takes it all... u.s. only.......  :bigsmile:
nivvy
« Reply #2 on: June 14, 2008 - 02:26:17 PM »
$215 to your door takes it all... u.s. only.......
nivvy
« Reply #3 on: June 15, 2008 - 11:29:04 AM »
$210 to your door takes it all... u.s. only.......  ths is a steal....
« Last Edit: June 17, 2008 - 05:30:26 PM by StRoKer »
nivvy
« Reply #4 on: June 17, 2008 - 07:17:50 PM »
I compltely forgt to mention I have the pushrods I used for the iron head setup... they were about $100 and will sell for only $40 additional.....  :2thumbs:
They are comp camspush rods.......
you also get extra shaft(new) and adjusters and nuts (new)...
let me double check the price on the rods to b sure....
« Last Edit: June 17, 2008 - 07:28:44 PM by StRoKer »
nivvy
