Author Topic: Reverse Rod Interference  (Read 741 times)
Offline 73EStroker
« on: June 08, 2008 - 01:11:33 AM »
My 73 Chally 4 speed has an interference with the reverse rod to the X-pipe on the exhaust. I see the 70 model rod is a different shape from the rest. Why was that great big sharp bend installed on the 71-74 rods anyway????? Can I simply cut a piece from the existing rod, join it together again by welding (with a sleeve over it for strength) and then heat and bend to clear the X-pipe????
Barry (Salmon Arm)
Offline Changin Gears
Re: Reverse Rod Interference
« Reply #1 on: June 08, 2008 - 08:28:58 AM »
I have done this exact same thing (without the sleeve) for the same reason.  Never worried about the strength because I do very little power shifting into reverse.
Offline 73EStroker
« Reply #2 on: June 08, 2008 - 10:30:00 PM »
Thanks. That is what I will do then.
Barry (Salmon Arm)
« Reply #3 on: June 14, 2008 - 04:17:46 AM »
