hi guys,
i have an A833 in my car (originally a D34 torqueflight car). it's got a few issues, thought i'd quiz you guys on what you reckon could be wrong with it. so i can begin to budget for parts needed.
i plan on getting it rebuilt when i can afford it, hopefully soonish.
it's pretty notchy and rough shifting, i had the shifter rebuilt when i first bought the car, but i think i should have just bought a new shifter.
the main problem is second gear.
synchro is gone, it will shift in ok if the revs are right, but will drop out of gear as soon as you let off the gas.
maybe dog teeth damaged as well? bent shifter fork? the shifter rods seem correctly set up,
although i haven't yet had someone run the shifter through the gears while i watch the rods work the tabs on the gearbox side plate.
the shifter also gets jammed pretty tight sometimes on the 2nd - 3rd shift.
shifter handle rattles when accelerating hard in 3rd.
the gearbox makes a bit of noise too.
i guess it sounds like i need a new shifter as well as a rebuilt gearbox...
also the clutch (which i had rebuilt when i had the shifter done) disengages right at the very start of the pedal travel.
it vibrates all the time too.
what are your thoughts? are these common problems?
cheers,
aaron
