Author Topic: New Direct Connection valve covers  (Read 1359 times)
Offline mrob
« on: June 09, 2008 - 01:33:46 PM »
Hi,
Has anyone used the new direct connection valve covers on a big block yet?
The reason I'm asking has to do with the size of the openings in the valve covers. Each valve cover looks like it has a hole in it about the size for a PCV grommet. So one valve cover can have a PCV valve hooked up to it, but the other one has an opening too small for a regular oil cap (at least that's how I see it). Maybe these valve covers require a special size oil cap? Maybe you can use a push-in style breather instead of an oil cap? I don't know.
Offline mrob
Re: New Direct Connection valve covers
« Reply #1 on: June 09, 2008 - 03:24:02 PM »
Just so that you get an idea of the size of the openings, I'm adding a pic. See how small the opening is on the one valve cover shown? The other opening (not shown) is just as small.
« Reply #2 on: June 09, 2008 - 06:22:42 PM »
The cover on the left seems to have a cover on the right side of it?   :clueless: Maybe the breather element hole is under it?   :1zhelp:
I'm clueless on this one.   :faint: On my covers, the breather is removed to add oil.  You can see in this cruddy pic, my PCV valve on the passenger's side, and my breather on the driver's side.
« Last Edit: June 09, 2008 - 06:33:19 PM by MEK-Dangerfield »
Offline mrob
« Reply #3 on: June 10, 2008 - 09:00:31 AM »
MEK,
Thanks for the pic of your engine. I think the openings in your Mopar valve covers must be the same as the Direct Connection covers. PCV valve in the rear of the right-hand cover and breather/oil cap in the front of the left-hand cover.
Do you happen to remember what the dia. is of the breather (where it pushes into the grommet)?
« Reply #4 on: June 10, 2008 - 11:38:37 AM »
MEK,
Sorry, I don't.   :banghead:
Offline 71bigblock
    • Steve's Mopars
« Reply #5 on: June 10, 2008 - 01:28:14 PM »
Hey Mike, it almost looks like that engine block is red or something...
 :lol:
« Reply #6 on: June 11, 2008 - 07:29:36 AM »
You do know that mopar offers a valve cover accessories kit that has several different grommets with it.
« Reply #7 on: June 11, 2008 - 11:48:48 AM »
For what it's worth, I don't have a grommet where my breather is. There a rubber stem attached to the breather that I just force into the hole in the valve cover. It's nice and snug.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #8 on: June 11, 2008 - 04:12:24 PM »
Most are 1.22" from what I have seen.  Take a look in a Summit catalog for common sizes.
Tom
Tom
« Reply #9 on: June 11, 2008 - 04:50:46 PM »
Tom
Tom,
  I was going to say mine was an inch and a quarter in diameter, but I didn't want to throw that out there without being sure.  :misbehaving:  Yes, my breather element is from Summit too.
