Author Topic: Dragstrip tech updated, Need help with 60' times  (Read 8899 times)
Offline 422STROKER
  • Member Since 6/3/06
Re: Passing Tech at the Dragstrip?
« Reply #15 on: June 13, 2008 - 03:55:03 PM »
I asked over there and got less answers than here even though they go.  No biggie, from what i can tell all I need is a helmet and maybe a clamp on my overlflow tube to the tank. And long pants too.
I don't expect to go anywhere near driveshaft loop or cage territory.  Just want to open her up a bit.  Have only floored the car twice.  1st time was my G-tech run and second time I had my wife in the passenger seat, she told me to never do that again.LOL
Tom :bigsmile:
Tom
nivvy
« Reply #16 on: June 13, 2008 - 04:00:19 PM »
Tom :bigsmile:
put a driveshaft loop in........  :2cents:
Offline 422STROKER
« Reply #17 on: June 13, 2008 - 04:05:13 PM »
I should but won't have time to do it.  I think I'm going to get about 3-4 runs in.  I might stop after 2 anyways.  i like that bolt on one like you got but I need to save my  :2cents: for it.  Otherwise the chepies seem like a PITA to put in and I would have to take out the seats and carpet to do it and that isn't happening a few weeks from Carlisle.
Tom
Thanks Stroker, I think tech up at NED actually looks at the cars from what I have heard but I should be good to go.  I haven't bought a helmet yet though.  Hopefully I'll run fast enough to require it.LOL  I would buy one anyways for some safety.
Tom
nivvy
« Reply #18 on: June 13, 2008 - 04:26:47 PM »
I have this one... 1399 ad quicker requires  helmet... borrow one....
Offline GoodysGotaCuda
« Reply #19 on: June 13, 2008 - 06:22:09 PM »
i have the same one stroker has on my car, and there is a HUGE difference in power between our cars...i just rather have it on there! Also playing devils advocate for 'not running one' when you go out this first time Tom. You'll be running those street tires that you currently have on there? I really doubt you'll get enough 'hook' to hurt anything...but its nice having one. I do believe you have to run a loop starting at 13's running slicks..not sure the rules on w/o slicks.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 422STROKER
« Reply #20 on: June 13, 2008 - 07:46:07 PM »
I didn't want to put sticky tires on for that reason, no hook no break.  At least that is what I tell myself.LOL
I'm running these 255/45/17s so I don't plan on having any traction down low.  Just going to walk it out 1/2-3/4 throttle and then have at it.
Tom :2thumbs:
I still plan on driving to Carlisle so I really don't want to break anything.....
Tom
Offline 422STROKER
« Reply #21 on: June 26, 2008 - 12:01:52 AM »
I ran a 13.43 @ 105.62 w/2.26 60'.
Tech was ok, Battery hold down, overflow, lugnuts, and neutral safety switch.  And the helmet check too.
Tom :violin:
Tom
Offline NoMope Greg
« Reply #22 on: June 26, 2008 - 12:25:52 AM »
60' and et say traction issues, mph says the power is there for more.  Bet that was a lot of fun.  :bigsmile:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #23 on: June 26, 2008 - 01:42:09 AM »
 :iagree:, mid 13s is not easy
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #24 on: June 26, 2008 - 03:04:16 AM »
Sound good to me for a street small block.   :2thumbs:
Offline 422STROKER
« Reply #25 on: June 26, 2008 - 06:12:31 AM »
Thanks guys.  Next time maybe some stickier tires will help a bit.  And a trans that doesn't run away a bit when shifting.(And a better driver :smilielol:)
Tom
Tom
« Reply #26 on: June 26, 2008 - 09:02:35 AM »
12s are no problem with that kinda mph! Now just get off the line.
1976 Dodge Warlock
nivvy
« Reply #27 on: June 26, 2008 - 01:25:03 PM »
once he 60fts the mph will come down... I thinks it "might" just dip a 12.8 - 12.9 ..... on et streets......  :2cents:
Offline 422STROKER
« Reply #28 on: June 26, 2008 - 02:24:17 PM »
thanks guys, after i do the new trans and coverter i'll get some stickier tires. :bananasmi
Tom :2thumbs:
Tom
Offline 422STROKER
Re: Passing Tech at the Dragstrip?2nd time.LOL
« Reply #29 on: August 07, 2008 - 06:33:03 PM »
Hey everyone, thought I'd keep it all in the same place.LOL
I am in the process of getting a driveshaft loop and some stickier tires.  i have a qustion on the driveshaft loop, here goes, what is the wording in the rule book as far as material specification?  I here 1/4 " steel, but also that if it is 2" wide x 1/4" thick it can be another material?  Can someone set me straight here?  I see some thick Aluminum ones for sale out there and wonder if they are leagal?
Tom
Going to run some 275/50/15's with my new driveshaft/loop and trans combo.  Hopefully it won't go any slower.  But with the heat who knows.LOL
My first water box burnout should be a trip.lol
Tom
