Author Topic: Dragstrip tech updated, Need help with 60' times  (Read 8898 times)
Offline ntstlgl1970
  • T a c o c a t
Re: Dragstrip tech updated, Need help with 60' times
« Reply #75 on: October 15, 2008 - 02:08:55 PM »
KYB's are high pressure shocks not really for drag racing. Try unbolting your front sway bar end links, that will help the front end rise. This was good for about 1 to 2 tenths on my car.
« Last Edit: October 17, 2008 - 02:23:31 PM by ntstlgl1970 »
Offline Grancoupe
« Reply #76 on: October 16, 2008 - 04:46:57 PM »
The 80/20's are valved in a way that will keep the front end up for a longer period of time. Good for launching and staying hooked through first.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #77 on: October 16, 2008 - 05:39:32 PM »
Thanks, what are stock fronts valved at?
Tom
Tom
Offline ntstlgl1970
  • T a c o c a t
« Reply #78 on: October 17, 2008 - 02:22:56 PM »
KYB, Monroe and other "stock" shock models generally don't publish their ratios. You are only going to get a 90/10 or 80/20 in a dedicated drag shock or in an adjustable.
