Author Topic: horn wire  (Read 2567 times)
Offline JasonTx
horn wire
« on: June 10, 2008 - 05:55:06 PM »
  :dunno:  The car didnt have a horn,, so i put one in and im trying to hook it up to the original spot instead of adding a push button under the dash. What i need to know is what color is the horn wire that comes out of the bottum of the column. There is like 4 or 5 of them and i dont want to spice into the wrong one. Theres like pink, green, red with tracer and so on.. I took off the horn cap and that black wire is hooked up.
Offline 422STROKER
  • Member Since 6/3/06
Re: horn wire
« Reply #1 on: June 10, 2008 - 06:19:05 PM »
What year?  The wires should be under the hood or behind the grille already.  Horns weren't an optional item.  Unless you have an aftermarket harness.
Tom :2thumbs:
Tom
Offline FY1 RT SE
Re: horn wire
« Reply #2 on: June 10, 2008 - 06:21:45 PM »
Offline JasonTx
Re: horn wire
« Reply #3 on: June 10, 2008 - 06:58:51 PM »
Its a 1970 cuda. But it didnt have a horn or anything when i got it. So im not sure if the wire is there or not. Thats why i was looking at the wires right under the dash to spice in to it and run it if it wasnt there
Offline 422STROKER
Re: horn wire
« Reply #4 on: June 10, 2008 - 07:44:19 PM »
I think on the 70's it is under the hood near the wiper bottle.  Front left if looking at it from the bumper.  Should be 2 loose wires(one has 2 wires in the connector the other has one)
Tom
Tom
Offline matt63
Re: horn wire
« Reply #5 on: June 10, 2008 - 07:48:50 PM »
I would find a '70 service manual with the electrical schematic which should show which plug and pin on the firewall bulkhead connector is for the horn and then trace the engine harness wire to find out where it terminates.  I only have a '73 manual.  On the '73 it is a dark green wire on the "K" pin.  The oil pressure sending unit, regulator and ballast wires are on the same plug.  IIRC one plug is for front lights, one for engine and one for accessories.
Matt in Edmonton
'68 Valiant
Offline JasonTx
Re: horn wire
« Reply #6 on: June 12, 2008 - 05:08:54 PM »
Still haveing trouble. Im bout to just start new with it but not to sure how to do that. Its frustrating trying to figure this out. :(
Offline JayBee
Re: horn wire
« Reply #7 on: June 12, 2008 - 06:52:04 PM »
According to my '70 service manual. The black wire with the white tracer(as pictured earlier) is the "horn ground". The "horn feed" is a dark green with red tracer wire. One end terminates at the horns, as said before, somewhere by the washer bottle. That DGN/R* comes from pin 24 of the bulkhead connector. It looks like it's the top left of the outside large one in the book. I'll look at my car when there's more time.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline FY1 RT SE
Re: horn wire
« Reply #8 on: June 13, 2008 - 12:04:25 AM »
Do you have a relay?  Sounds like you nedd to get a FSM.
Re: horn wire
« Reply #9 on: June 13, 2008 - 12:10:01 AM »
check that this is in place on your fuse block
http://www.partsamerica.com/productdetail.aspx?MfrCode=BOR&MfrPartNumber=R213&PartType=409&PTSet=A
Offline JasonTx
Re: horn wire
« Reply #10 on: June 15, 2008 - 11:47:11 PM »
Dont think i have that. im going to look
Thanks
