Anyone want to reassemble my Cuda?
Author Topic: Anyone want to reassemble my Cuda?  (Read 4209 times)
Offline vryfast
  • WORK IN PROGRESS
Re: Anyone want to reassemble my Cuda?
« Reply #15 on: June 13, 2008 - 10:39:33 PM »
 :money: :money:
Offline vryfast
  • WORK IN PROGRESS
« Reply #16 on: June 13, 2008 - 10:41:08 PM »
 :cooldancing:
Offline vryfast
  • WORK IN PROGRESS
« Reply #17 on: June 14, 2008 - 03:07:35 PM »
i'm try to install the fuel tamk. any one have some pictures of the fuel tank looking back from the rear axle mine looks to close the the pumpkin. also do you have to install the fuel tube from the trunk before you install the gas tank ?
Offline vryfast
  • WORK IN PROGRESS
« Reply #18 on: June 14, 2008 - 07:10:07 PM »
any one know where i can buy the rear upper bolts for the shocks ?   also did i do something wrong here or the rear brake block? the red line is where the vent tube goes and i thought it should hold the brake block but the block is about 4 inchs away. any suggestions
Offline vryfast
  • WORK IN PROGRESS
« Reply #19 on: June 14, 2008 - 07:11:19 PM »
here's a picture of how close the gas tank is to the dana
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #20 on: June 14, 2008 - 07:43:22 PM »
Wow I will try to help I do not have pictures yet of my car to show you.
However, the break lines should follow the axel tube as in being in contact with it all the way down the tube.
Someone may be able to post a pictures for you I will see If I have any..
The dana 60 aftermarket cover is larger than a stock one obviously did the manufactures say it would work with a stock tank? I would think if at full compression of the springs if you have about ½ inch of clearance you should be ok with it. You have some nice stuff.
Hope this helps.
Go Fast & Have Fun...
Offline vryfast
  • WORK IN PROGRESS
« Reply #21 on: June 14, 2008 - 09:12:25 PM »
thanks  I also need pictures of the front brake lines and how the run across the firewall.  fuel line next ! :bigsmile:
« Reply #22 on: June 14, 2008 - 09:15:09 PM »
Cool car, but you may wanna start your own thread on all this.  And keep us up on it's progress.  People can keep up with it better and you wont be high jacking Jeryst thread here :2thumbs:
Offline vryfast
  • WORK IN PROGRESS
« Reply #23 on: June 14, 2008 - 09:27:20 PM »
oh sorry about that didn't mean to hijack i will move now !!!! :2thumbs:
Offline jeryst
« Reply #24 on: June 16, 2008 - 01:38:47 AM »
Just got a call from someone that wants to buy my Cuda for $18k as is.
Anyone have an opinion?
I may just sell it and buy a driver. Thats about the only way I'll have a Cuda to drive anytime soon.
