Author Topic: 70 Dart hood scoop question  (Read 653 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« on: June 12, 2008 - 12:29:58 AM »
Does anyone know the mounting location for the stock dual hood scoops for the 70 dart? I am going to install a set but don't know where they mount.
1996 Dodge Viper GTS Coupe
Alaskan_TA
Re: 70 Dart hood scoop question
« Reply #1 on: June 12, 2008 - 12:35:37 AM »
The underskin is pre-punched for most of the holes. Some hit in the "field" where there is no underskin.
Let me search for a photo.......
Alaskan_TA
« Reply #2 on: June 12, 2008 - 12:42:24 AM »
Found it, this is the passenger side. The holes outlined in yellow are pre-punched in the underskin.
The holes outlined in red are in the field and not marked.
Drill the yellow holes first, in the center of the punch-outs.
Then, take the opposite side scoop and line it's studs up on the UNDERSIDE of the hood. Mark the last locations that need to be drilled that way.
Check 8 times, drill once just to be sure, I have not done it for a decade or two..........
Offline 72hemi
« Reply #3 on: June 12, 2008 - 12:53:05 AM »
That's perfect. Thanks Barry.
